Interior is painted. ?
			@scullyg40 I'll be watching with interest as to how much you save from the doors by gutting them and going poly/lexan windows.
you're right! looking back it was your thread I got the recommendation from haha!Thanks, but I've got the same one. Just didn't have the time to mount it yet.
My left brake pad has crumbled. They are Carbon Lorraine RC5+ and I did my first trackday with them in march 2018. Since then I did about 8 to 10 trackdays I think, with an average of 4 to 5, 20 to 30 minute sessions. Is this normal that they gave up after this amount of track time?
Might it also be heat related that they have crumbled? Should I upgrade to RC6 or higher, or a different brand of brake pads?
God I miss driving mine on track. Great to see you're still at it!
Then fix your damn car.
				 cliosport.net
					cliosport.net
				How much polycarb did you get mate. I'm going to do the same.
@scullyg40 Whats your plan with the laguna/cup racer hubs? I got a pair recently but its the coilover that is the problem, either find some original ones or get your ones custom mounts
				 cliosport.net
					cliosport.net
				Some big changes to be made! So you will be using those mounting brackets on the bcs.. And do you have alignment settings in mind? If It was me Id be going for a lot of caster, but I know you use manual steering which will make the steering even heavier, as the increase in mechanical trail.
Also can you post bigger pictures? I couldnt see the diy poly bush very well
