Realtime Graphics / Game Engines
SharkyUK
I haven't touched my path tracing project for a while and decided to upgrade it to use the latest version of CUDA this evening. It didn't work out so well, so it's now going to be a job for another time! 🤣 However, I did make a few tweaks and improvements in readiness for the forthcoming 50xx series GPU from nVidia and I'm looking forward to getting my hands on one or two of those. There are also one or two features that I want to introduce into the renderer to see if I can get them running in real-time and without too much of a hit on performance.
I've not got much to show and the changes I have made won't show up that well in the generated imagery, but here are a few more renders for shizzles and giggles.
SIPT2 Render by Andy Eder, on Flickr
SharkyUK
I decided to spend a couple of days fixing some long-standing bugs with my path tracer. The main culprit has been causing me headaches for a couple of years now and has been a b!tch to debug. I found it after a 14 hour debugging session. I was using variable "nl" when I should have been using "n". But had only made this error in one place in the code. Every other occurrence was fine. :ROFLMAO:
Feeling a bit happier now it has been fixed. :LOL:
This first image was rendered using Blender (Cycles render engine) - which I use as a benchmark for my own stuff.
(Blender)
And this next image was rendered using SIPT2 - my real time path tracer...
(SIPT2)
I'm quite happy with that. (y)
A few more random renders for good measure.
SharkyUK
As always - very impressive stuff that my brain would probably comprehend 1% of!
You'd have spotted the bug straight away, mate. (y) It's quite obvious when you think about it. When calculating a ray's path at the interface between different materials (involving dielectrics - which are non-conducting and transparent and can both reflect and refract a light ray), and assuming the ray does not end up in total internal reflection, when calculating the probability of of either generating a reflection or transmission/refraction ray, you need to use the underlying geometry's raw normal. I was using a corrected normal based on microfacet theory by mistake. The corrected normal for microfacets should be used for shading and calculations in general, but not when it comes to deciding if the ray should be reflected or refracted. It messes up the probability distribution, adversely affects light radiance weighting, and breaks the law of energy conservation. And can muck up the rendering. The issue was that the messed up render is not too dissimilar to a physically correct render, hence why I kept missing the issue. Piece of cake, y'see. :LOL::ROFLMAO:
Matt Cup
  Iceberg 172 Cup
Indubitably!
SharkyUK
With plenty of time on my hands, I've been updating and reworking a few bits on my path tracer project, as well ass adding a few new features.
The under-the-hood stuff for the path tracer operates in linear RGB HDR (high dynamic range) space (it's not spectral yet, but that's a HUGE rewrite). At some point, for display on regular display devices or saving to non-HDR file formats, the HDR image needs to be transformed (tone mapped) to LDR (low dynamic range). This can be quite a tricky process as you have to try and preserve image detail in dark areas as well as excessively bright areas, and then somehow map those extreme colour intensities in to a [0,1] range (or [0,255]) RGB.
TLDR; take the rendered image from the software and make it displayable on HDR and regular display devices by dicking around with the colour range. :ROFLMAO:
This is done through a process called tone mapping. In the past, I used a naïve Reinhard Luminance tone mapper (or simply cut any values off that fell out of the [0,1] range. This didn't produce the best results. So, I decided to pick a few different tone mappers and implement them.
Implemented ACES (which gives a nice punchy look), AgX (which is more realistic and probably the best one for use in a render + vfx + post-production workflow), and in improved Reinhard.
Probably not the best 3D scene to show the differences, although they can be observed in the image below.
I also decided to rework my post-process bloom effect as I wasn't happy with my old version. It's a lot quicker now, and produces much better results. It is not physically realistic (far too expensive for a real time renderer) but it does the job and is user-controllable.
I also added a reworked "sheen". It's based on "Practical Multiple-Scattering Sheen Using Linearly Transformed Cosines" (Zeltner, Burley, and Chiang, SIGGRAPH 2022) that introduces a method for real-time, physically-based rendering of fuzzy or dusty materials. It models sheen as a volumetric layer containing fiber-like particles (using the SGGX distribution) and approximates the resulting multiple scattering using an LTC fit, replacing expensive simulation. Good for clothing and things like velvet. Quite happy how this turned out.
In addition, I reworked my transmission code that models light passing through a surface for things like curtains, or strong sunlight shining through leaves. Good for backlighting! Here is an example of a bright light under a piece of fabric.
And a bright light shining through stained glass:
Another area to update was the coat (clearcoat) processing; this is good for adding a gloss/lacquer layer on top of an existing surface/material. For example, the lacquer layer over car paint, or even moisture/wetness on skin. Or varnish on wood. That sort of thing. I gave the McLaren in the image below a dull Papaya Orange paint layer with high roughness - which meant it appeared diffuse with no highlights - matte orange if you like. I then applied the coat on top which simulates the lacquer clear coat, and suddenly the paintwork has reflections and gloss as you would expect to find in the real world.
A woman:
A sweaty woman:
Bored yet? :ROFLMAO:
SharkyUK
Well, the upgrade to CUDA 13.1 didn't last long... now on 13.2... :ROFLMAO:
Whilst I am still looking for my next job, I decided to update my path tracer and implemented an improved light scattering system. Rays travelling through a 3D scene now interact with participating media (e.g. particles in the atmosphere) if present. It's quite an expensive process, but gives some cool results - such as realistic fog. Mixed with a 3D texture, it can also be used for rendering volumetric clouds, flames, etc.
Mr Squashie
CSF Harvester
  Clio 182
No doubt you've seen this already, but some of these demos are ridiculous. The Starfield one is especially impressive given that the game doesn't even use basic ray tracing, let alone path tracing.
dann2707
I think you collectively destroyed Primarks WiFi on Friday when I was in there loitering around waiting for the Mrs and I tried loading this page up 😂
Was genuinely like being back on dial up when the images just bit by bit load up progressively 😂😂😂
SharkyUK
Yeah - there is some crazy stuff coming. DLSS5 has ridiculous potential (despite the early hate it is getting from folks losing their s**t over it - which is hilarious to see! It is such a misunderstood technology). I think it is going to be a tough ask to have it up and running before the end of the year in mainstream DLL and driver releases... but I also have to say that the speed at which the AI and ML stuff is evolving is staggering. DLSS5 ability to "understand" lighting and material response is on another level. Path tracing without having to path trace. :ROFLMAO:
It's stupidly hungry though in terms of the processing oomph that is needed. It will be interesting to see where the major performance increases come from in order to see it running on a single GPU with a respectable modicum of performance; even on high-end 50x0 series GPUs. It's not just DLSS5; there are some other changes and new tech coming along to support it and that looks pretty special, too.
Sorry mate! :ROFLMAO: I have a few more coming soon. I've been working on extending my path traced volume support to align with with DreamWorks Animation developed - as seen in movies such as the newer Star Wars, Marvel movies, etc. Admittedly, my version is cutback a bit as I am trying to run it in real time rather than have a data centre of 10,000 GPUs render it over the course of a week! :p
dann2707
SharkyUK
Another productive all-nighter :ROFLMAO:
My last set of images showed how I had been working with light scattering through a volume of participating media - or path tracing light bounces through a dusty/smoky/etc. bounded region of 3D space. Those images were based on volumes of constant density, hence showed little variation in terms of light scattering. Just like a fog of a given density to put it into simpler terms.
The next logical step was to use volumes of varying density to show more interesting results - such as smoke, clouds, flames, that sort of thing. I looked at OpenVBD, which is now an industry standard having initially been designed and introduced by DreamWorks Animation. However, I first had to spend a bit of time writing a parser to take example data sets I wanted to use, and to convert them into a format my path tracer could ingest.
Here are some of the results:
It is an insanely expensive process in terms of both storage requirements and tracing the volumes! :ROFLMAO: But the results are pretty good, even using a single-scatter approach (whilst I think about how I can improve performance for a multiple scatter system).
Stats for nerds - based on the "bunny cloud":
  • Dataset: ~150 million voxels (~600 MB float volume)
  • Resolution: 4K (8.3 million pixels)
  • Rendering: 1 sample per pixel per frame (progressive path tracing)
  • Framerate: 60 FPS (~60 samples per pixel per second)
Per frame (at 60 FPS):
  • ~8.3 million primary rays
  • Up to ~200 million ray interactions (assuming multiple scattering bounces)
  • ~3–4 billion voxel density samples (ray marching through the volume)
Per second (accumulated):
  • ~500 million primary rays
  • ~10–15 billion ray interactions
  • ~200–400 billion voxel density samples
Of course, these are order-of-magnitude estimates, not exact counts!
  • Not every ray goes full 24 bounces
  • Many terminate early (Russian roulette, absorption)
  • Some rays exit the volume quickly
Rendering this bunny once at 4K involves more individual calculations than a modern CPU performs in several seconds. Path tracing is expensive! :ROFLMAO: I'll make another video of it running in real time at some point.
Crispy.
  BMW G31 530D Msport
Impressive stuff... I have not a clue about a lot your saying but I am glad you have included cool pictures :LOL:
I loaded up trusty ol' MSP and gave it my best shot. No success with the light scattering, but I've impressed myself still with the end result.
SharkyUK
A few more pics for @dann2707 to look at whilst in Primark. Not quite up to @Crispy. level but that is what I'm aiming for! :ROFLMAO:
I spent another handful of days extending and improving the rendering of 3D volume datasets in my path tracer. It now supports emission/temperature so that flames and heat can be used in conjunction with a volume's density channel (smoke, debris) to create explosions, smoking flames, and suchlike. It's no longer limited to just fog, smoke and clouds!
All images are raw outputs directly from the path tracer.
(y)
SharkyUK
More renders...
And a video showing improved support for analytical primitives. "What are analytical primitives?" I hear you say... :ROFLMAO: They are objects that can be represented purely by a mathematical function rather than created as a mesh comprised of multiple polygons. Objects such as spheres, cylinders, planes, capsules, boxes, etc. My path tracer has supported these for a while, but they were hardcoded directly in the software. Now, the user (me) can add, remove, and manipulate them in real-time through a built-in editor.
Yeah. Exciting. I know. :ROFLMAO:
