Its going to be a little beast!!
Very nice mate. Got any test/track days booked before the season opener in April Dave?
What size feed pipe are you using into the 044? It looks like -6 or -8? Either of those sizes are a bit on the small side and you risk the 044 pumping more than can be supplied. I speak from experience mate.
You want -10 or -12 mate. The 044's flow so much fuel -6 just isn't enough. For my setup I'd got a high flow pump acting as a lift pump and the 044 after the swirl pot. The pump became noisy and hot after time. The reason for this was that it was flowing more fuel than -6 supplied so it was being starved of fuel. Put it on a larger bore feed and no more noisy or hot pump. The 044 will quite happily die if you run it dry as well btw.Thanks for the heads up, Its -6.
Tell me more about your experience please.
No problem mate.Thanks for the heads up @NorthloopCup ,
Nice one, good trip up north mate?
