Thank you mateWow what a great read, not sure how I missed this!
As for the 280mm vs 300mm disc dilemma I'd get 280mm discs as well if I were you.
I've got 300mm discs and it looks great but it's a pain with the tight clearance, wheel weights and spacers/offsets.
Yeah, they are growing on me. I think once the ducting is in, it’ll be better.Bass ports look alright though!
Not had many issues with my pins, altough I do remove them a couple of times a year, clean and refit and now changed for Mr pink pins, definitely the way forward.
Cheers fella, I’ll have a flick through your build again and grab the part numberLooking good dude. I replaced the clips on my front bumper with some really hardy ones from Subaru. Holds it all right so the body lines match properly.
Part number is in my thread somewhere (nearer the start I think)
Not good for the bank balance though, haha!That's a good shopping list!
Where are you getting the calipers machined? I'm looking to get my brembos machined for the PMS 280 brackets as well.
Also interested to know if you think the 197 master cylinder makes a big difference.
Cheers mate!nice car. will need to keep an eye out for you if you are around Edinburgh. I am just along the road from rentec use them all the time for any work, need to book mine in for service and some polybushes and engine mounts to be fitted.
Who refurbed them? Guessing they didnt remove all the engrained brake dust first?Took it out for a drive for the first time in a week or two today and this popped up after round 20 miles. (Brother took this pic from the passenger seat, not me!)
Stuck in limp mode and limited to 2.5krpm. Plugged the code reader in and nothing came up. The previous owner changed the throttle pedal sensor in 2019, I’ve cleaned the white plug and checked all connections in the bay when I had the front end off recently. Maybe it’s time to give the white plug another clean?
A quick look on here suggests it’s either a dodgy loose wire somewhere or a dodgy TB? Anyone else had this and solved it? This is the second time it’s happened since I picked the car up in March 2020 and there’s no rhyme or reason to it. It happened with no warning sign, then clears with a code reader and runs spot on for ages.
Ending on a cheery note, here’s a pic of the 197 Bremboall machined and refurbed.
Plus some nice braided hoses from BRT
MS Engineering.Who refurbed them? Guessing they didnt remove all the engrained brake dust first?
It more looks like theyve not been blasted properly to remove the remnants of brake dust mate, are they raised up or divets? Doesnt make a difference anyway as the bit that looks good faces outwardsMS Engineering.
They were proper knackered when I bought them and were cheap for a reason. Looked like they’re been kicked around the blokes garage for a few years, hence why the inner caliper has some heavy chunks out of it/chunks out of the mounting area. As long as it mounts fine, and stops well then I’m happy enough.
Looks like divets or they've been battered to me. I'd have expected MS to fettle them up a bit before painting though.It more looks like theyve not been blasted properly to remove the remnants of brake dust mate, are they raised up or divets? Doesnt make a difference anyway as the bit that looks good faces outwards![]()
The pms 280 brackets have bosses on that sit in the caliper. That gives enough bracket to screw a bolt into.Now that is a f**k tonne of corrosion!
Do the PMS studs for the calipers have shoulders I'm guessing? Hence the machining
Exactly what @Porl said above. I’ll fire up a pic of the brackets when the postie delivers them this weekend.Now that is a f**k tonne of corrosion!
