Seeing as ive had the metal sat in my garage to make myself a 5th mount for a few days now, i finally had abit of free time along with jord to get one made. There was alot more work involved in making it than i first thought but it was all worth it. And the end result was great. Took about 4 hours of grinding, measuring, welding, drilling, abit more gringing then spraying but it looks great. Took alot of pictures along the way. The main ourpose of putting the 5th mount on is to further reduce any engine movement along with the solid dogbone.
Firstly i started out with a 250 x 250mm sheet of 3mm thick steel plate. I cut this in half so that i could make both parts of the 5th mount.
Then we drilled a hole in the subframe so the the rubber could be fixed directlty to the subframe.
Jord had brought one of his spare blocks with him so that we could measure and find the positions of all three bolt hole for the 5th mount to be mounted to.
Then we cut out a rough template using paper so we could get the rough shape and positions of the bolt holes.
Marked all three holes up on the paper template.
Then transfered the paper design onto the sheet of metal and cut it out with the grinder to get the rough shape.
Then we made a slight notch in the sheet of metal so that it would clear the water pump housing yet sit flush onto the block.
Then abit more grinding.................
All the holes were drilled into thge metal for the three bolts to go through to the block.
A trial fit confirmed that all three bolts lined up with the holes in the block perfectly.
Then we had to drill a hole in the bottom of the subframe large enough to fit the nut and a socket through.....
We then set about cuttin out and shaping the piece of metal the would attatch the metal frame of the mount to the rubber......
Once we had the correct shap and size we drilled holes for the bolts to go through and attatched it to the rubber part of the mount.
We then went round all the edges of the mount with a paddle disc to get rid of any sharp edges and to define the shape abit more.
Now that we had both parts of the mounts made up and cut out we got a spare piece of roll cage tubing to reinforce the mount. This would stop any flex of the mount.
We took a few measurements of the angle we want the mount to sit at so that it is forcing the engine against the dogbone mount.
Got the welder at the ready.......
Once we had cut the roll cage tube to the correct length, and with the correct cuts so it will support the two pieces of metal, jord set off with the welder.
10 mins later we had a complete 5th engine mount.
A few coats of paint later.
Attatched the rubber to the bottom of the mount.
Then put the ount on the car. Sorry for the bad pictures it was dark by this point lol....
Perfect fit, job done.
Just need to adjust the dogbone mount now so that both mounts are forcing against eachother.
