UPDATE
I spent a few hours on the car saturday. My plan was to remove most of the bits from the engine bay so i can clean everything up, powdercoat parts i want to and just tidy every thing up. Allthough its a track car and its suppose to be function over fashion i just want to make the engine bay really tidy and clean. So here is goes.
First off i was greeted by two AA windscreen chappies who came to fit me a new windscreen after a little accident
So here was my old windscreen with a bit of a crack
Then they chopped it out
Then they fitted the nice new item
Nice new windscreen
So after that I started stipping the engine bay down, removed the bonnet and bumper and this is what i had to start with
So i drained the coolant, removed the radiator and all the coolant hoses.
Just removed the lights to give me more space
So time to remove the AC compressor so i went about undoing all the bolts and bits.
AC compressor removed
Alternator removed
Powersteering pump removed
The big brackets and small pullys removed
So its looking a bit more empty
Removed the ITB's and fuel rail, the allen key bolts were rusty and manky so i'll replace those with new stainless items when it all goes back together.
I then went about removeing all the engine bay loom
All gone
Also had to remove the gearbox mount and battery bracket thingy.
On removing it i found that it had broken :S could have been from the little Nurburgring kiss i had a few months ago allthough i actually think it may have broken way before that because there has allways been a buzzing when at 7000rpm and i think it could have been the broken mount. We will see when i put it all back together.
Next thing to do was to remove the ABS unit, i got all the lines off apart from one so i had to cut it which was a bit of a pain but never mind.
Then i just sprayed a little bit of degreaser over a few bits
After a bit of a clean
So thats it for this weekend, got a busy next few weekends so its probably just going to sit there for a while
My next plans are:
Powdercoat - wishbones, subfames, ITB Manifold engine mount, gearbox mount.
Paint the block, rocker cover, etc
Buy brake bias valve, braided hosing, T pieces and shizzle.
New alternator and belt
Oh the list goes on.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
