snapped engine (dogbone) mount
Reet, thing is i replaced this mount just less than 3 weeks ago. The other thing is i dunno if i did it right, i must have overtightened the bolts maybe??? wtf would it be??
And could someone please give me a step by step, for dummies, guide on how to change it. because im gunna do it again ;)
Cheers......
Dan
Id like this too please, gonna put a powerflex bush in there!
only time ive seen one snap is when my driveshaft went causing the gearbox to lock up and snapping the mount. car needed a new gearbox, driveshaft, mount, cat/downpipe.
as for replacing it its easy,
use a socket and a hammer to get the old bushes out, put the new powerflex polly ones in.
its 2 bolts that hold the mount on, i prefer to use a jack under the engine to hold it in place so its easy to bolt the mount back on again as the engine doesnt move when you take the mount off.
Cheers......
Dan
Undo both 16mm nuts and slide out the bolts, remove mount, put in new mount(only use genuine mounts, pattern parts dont last!), put in both 16mm bolts and do up.
Powerflex bushes make a massive difference!! i always said if i get another clio, only mods ill be doing is suspension and powerflex bushes in the mount.
the gearstick has no movement at all in it, it feels much tighter and better to drive
replaced it, i think i overtightened it, and also had the engine too high jacked up, its reet i hope this time. cheers for your help.
