So what next for my 182??
Car  M135i, 118 coupe
So at last ive decided to keep my 182, cause i freakin love.So shall i try and squeeze a bit more power out of it,and what should i do.
So far blueflame exhaust on order,itg filter in,(not keen on the idk's) So what next
Ok maybe remap (pmurry?)
Inlet matching?
Maybe a carbon splitter for styling,???
Dont want to buy a package as im saving up for tuning aspects individually.
Advice and opinions appreciated
Intake matching is the most important IMO.
Your best getting all the tunning bits at once as a remap only needs to be done once then.
182taunton said:
throttle bodies cost loads of dosh dont they???
Individual throttle bosies which i assume is being talked about are expensive you won't see chnage from £3k at best expect to end up paying near £4k with servicing etc.
talk to bbpt like i said before mate,they are developing a cheaper turbo kit(low boost) for the 172/182/cup
not sure on price though.
prob around £3-4k fitted
k-tec also would build one il bet! matched to what eva your budget.
also look on yozzasports site on here!he knows his stuff!
Will go faster if you spend money on brakes and suspension mate, as the teenie changes to the engine wont make much difference in the real world.
true about the brakes and suspension!
If I were to modify my car again I would only change brakes and suspension. Nothing else. If it's not quick enough for you, buy a car that is quicker. You will be spending thousands and thousands on these engines to get any good power out of them and it's not all that good in the end. You'll always want more...
Agreed - thats what i am concentrating on, only "engine" mod i've done is blueflame exhaust and even that was mostly for the sound. I'm going for uprated brake pads and lines next and when the discs are gone i'll go for some carbon discs too. Eventually I'll probably stick some Bilsteins on it.
