Subframe / rack removal
Ph1 Tom
The subframe is hanging off, the only part still holding it on is the rack but I can't see where the rack bolts to the column.
I thought it was the 13mm nut under the rubber gaitor on the rack by the bulkhead but I can't get that off because the stud spins and there's no way of holding it. So I figured it must be somewhere else..
Bend the tabs back with a pry at if poss as I'm guessing someone has put a differnt nut in at some time and used their fingers to hold it until the nut has nipped and now with a little corrosion its locked to the bolt.
Either that or the tabs are just bent and not holding the original nut properly.
Am I missing something? Removing subframe to take the engine out?
If your taking off the subframe to powder coat etc maybe wait until the engine is out?
