Test Fitted Cup Spoiler...
  Meg R26 + Mk4 GTTDI
although the wrong colour it looks great. i was told i would need a longer hose and a different adapter or something for the brake light? mine both worked fine? its a 2001 dynamique btw
was i told wrong info or what?
Some of the spoilers came with different connecters IIRC. Washer you can jus pull them out a bit further.
Car is the excact same as urs but is an Expression.
also the spoiler has never been off before until today but there is some dodgey black tape around the hose and the wires! renaults great build quality or what?
6 screws out
remove cable for brake light
remove hose for jet
remove standard spoiler
and then reversed for the new one
very very easy
someone on here for 130quid
when you open the boot there will be two on the left and two on the right
there will also be 2 in the middle inside a sortof black casing
you should know what i mean when you look for yourself
yea it looks fine to me
Ok cheers, at least i know how to fit one if i can find one. :)
