I think this page has tooo many pictures in it already but im updating it anyway!
Thursday 2[SUP]nd[/SUP] August 2012
Well the plan was to weld the front part of the cage in tonight but it didn’t quite go to plan.
First of all Luke and I profiled the 3 bars that we needed to attach to the main hoop so that the door bars could be connected to the main hoop. Once this was done we cleaned the paint off of the main hoop in the areas that Luke was going to weld.
Couple of pics:
Luke then set the welder up so that we could tack the bars in place so that we could remove the main hoop and weld everything up.
Unfortunately we had no gas and at the point of realising this it was 6.30 so the local shop to get gas from was closed! Massive fail.
Luckily we had another gas bottle (all be it for mild steel application) so we used this bottle just to put a tack on the cage. We will be scurfing this tack back once we fully weld the tube in position.
With those tubes now tacked in position we wanted to tack the front feet on to the roll cage so that we could remove it and fully weld around it. So we put everything in position and tacked the two front feet into position.
As we had no gas so could do no proper welding to the roll cage we removed everything from the car. We then cleaned up all of the areas that had paint where we needed to weld on the roll cage and inside the car.
Luke had kindly agreed to come around on the Friday to weld the front part of the cage in place so that I could crack on with the car over the weekend. Obviously after I had bought a new gas bottle.
We called it a night after that so packed up and went home.
Quick picture of the cage laid out on the grass:
(don’t worry it is not still there now it was put away in a dry shed lol.)
I got home to find this waiting for me. Just a cheap silicone hose that I am going to use to connect my airfilter to my throttle body adaptor (whenever it gets done!)
Friday 3[SUP]rd[/SUP] August 2012
Well to say that I have had some bad luck with this build is a bit of an understatement !
Luke came into work on the Friday and wasn’t feeling great so promptly went home at about 9am so he could go to the doctors. He went to the doctors who told him to go straight to the hospital with suspected appendicitis. Later the same night he had them removed so he is now out of action for 2 weeks minimum.
Kick in the balls for the project and the schedule but tbh I am just glad he is ok. I feel a bit bad as I told him to stop being a pussy that morning when he said he didn’t feel right.......but what are friends for lol. P.S I can now report he is on the mend and doing ok!
So with no Luke and not a great deal of motivation I decided to start wrapping my interior loom in self amalgamating tape. Brilliant stuff as its oil water resistant and it doesn’t leave a sticky residue should you need to remove the tape at a later date. Did the majority of the front part of the interior loom before running out of tape. Unfortunately no before and after pictures just yet. Once the new tape arrives I shall do.
Another mate Luke popped round to lend a hand as I made a start on wiring up the rear lights, fuel pump. I am taking a bit of a gamble as I have decided to use a PH1 interior loom (front part) and the back part I am planning on using a ph2. Not too sure how that will work out but we shall see.
So I cut all of the tape off of the rear loom and set about getting the Haynes and figuring out which wire goes to what plug. Pretty straight forward.....or so I thought.
Connected up what I thought would work but unfortunately it didn’t. It was as if I had completely wired everything up wrong. I checked it and checked it and checked it but still could not figure out where I went wrong.
I called it a night after that as I was getting a headache from reading the bloody wiring diagrams.
Went round to the girlfriends and she had these waiting for me. Another thing to cross off of the list!
Sunday 5[SUP]th[/SUP] August 2012
Did a couple of hours work on the car as my Nan was having a BBQ so I didn’t want to be too rude and just sit down tinkering with the car all day.
I continued with the wiring and all I managed to do was drain the brand new Odyssey battery I bought and the standard one that I got with the car. The standard one I don’t really care about I can trickle charge that but I am sure that the odyssey battery cannot be trickle charged as it is a dry cell. Does anyone have any idea without causing damage to the battery. Should I just try jumping it when the car is complete>?
Anyway after the batteries died I sacked it off for the night.
Sorry about the no pictures but wiring isn’t exactly interesting is it? Plus recently I have just had a habit of not stopping and forgetting to take pictures.
Monday 6[SUP]th[/SUP] August 2012
Got round to my Nan and granddads and first thing was first.....trickle charge the standard battery. Whilst I left that on I thought I would fill the car with coolant as I had finally remembered to bring a jug with me to my nans.
Spent ages filling the coolant up with a 50/50 mixture. I had to walk the length of the garden to get the water and the jug was only 2L FAIL. I got underneath to check for leaks and sure enough a pin drop every few seconds was coming off of the bottom rad hose! Wiped it clean and felt for any tear s in the hose. Couldn’t feel anything so tried to tighten the jubilee clip. It still leaked so I opted for removing the hose (and wasting a load of coolant!).
Removed the hose and bunged one end with and angle grinder handle, the other one with my hands and then the last port I blew down whilst the hose was submerged under water. I built up the pressure (as much as my lungs could do) and I could not replicate the leak. I examined the hose and it was fine. I then refitted the hose making sure that everything was fitted properly.
I then topped up the coolant and the pin prick leak came back. Tightened the jubilee and wiped it clean and touch wood it has been fine since. I think that I just didn’t have the jubilee clip sitting nicely. Oh well its working now!
I had found out earlier in the day that the positioning of the wires for the PH2 lights is different to the PH1. THANK YOU RENAULT! So armed with this new information I swapped the wires around in the plug and then re connected the MK1 loom to the MK2 plug. Tested it as the battery had been on long enough to use it for a few minutes. EVERYTHING WORKED.....apart from the MK2 brake switch. I still cannot get that to work with the MK1 loom. I wanted to check to see if it worked with he MK1 switch back on it and sure enough it did! Absolutely over the moon. So I can either fabricate the pedal box to accept the MK1 switch or I can get a new pedal box. If anyone has a pic of how the brake switch fits into the pedal box on a mk1 that would be greatly appreciated.
Quick pic of the front part of the loom and how the car is sitting (haven’t got a pic of the back loom yet)
Tuesday 7[SUP]th[/SUP] August 2012
I had thought about the fuel pump long and hard and I could not be bothered to try and get the MK2 pump to work with the MK1 loom. So I decided to fit the MK1 fuel pump.
Unfortunately it was not as straight forward as remove one and refit the other.
The hole in the MK2 tank is considerably smaller that the holes in the tank for the MK1 fuel pump so therefore I had to open out the hole. It took me quite a while to do this as I did not want to go to mad and have a massive hole where fuel vapour could escape from the tank (which is not good).
A few pictures:
Before:
After:
Fuel pump in place with the rubber seal:
Lovely job.
Also when I had found the wiring for the PH1 and PH2 light difference I had come across a wiring diagram done by foxy and matteh. It showed the difference between the PH1 and PH2 brown plug. Where the wires are and what they are. With this in mind I didn’t think that I would be able to use the PH1 main interior loom and the PH2 rear part of the loom.
I then decided to start stripping down the Phase 1 loom of the tape and the unnecessary wiring. The plan now is to use the PH1 rear part of the loom and splice in the PH2 fuel pump plug in. The problem is I need a PH2 fuel pump plug.....can anyone help me out? Obviously I will need to splice in the MK2 rear lights as well but that easy now I know how lol.
I am hoping this will still be done for the September deadline but that will all be dependent on how Luke feels and when he will be up for the remaining welding. There is still a lot to do.
Weld Front part of cage,
Repair sills where we chopped for the cage to fit
Profile and fit the bars that go to the suspension pick up
Make and fit a harness bar
Finish fuel pump wiring
Check wiper wiring
Tape the entire loom
Touch up interior and cage where welding has to be done (matt Black)
Mount clocks
Make switch panel
Fit top dash
Fit indicator and wiper stalks
Install Fire Extinguisher
Install battery
Install isolator switch
Weld passenger seat subframe
Plate holes in car
Run fuel lines
Make and run brake lines
Bleed brakes
And probably still more things to do.......
More updates soon.
Thanks for reading and as always comments always welcome.
