UPDATE:
Not much had happened recently with just a lot of other things on, mainly work 24/7 but this weekend I got a bit more time on it.
First job was to tighten the rear suspension, for some reason one side was loose. I got it all apart, had both rear shocks off, matched everything as I re-assembled them and re-attached all to the car and dropped it back onto its wheels.... IDIOT... now I had 2 loose rear shocks.... Everything off again, both shocks off and find the issue. I had a good idea what it was....
The image above shows the metal shim sat below the circlip on the shaft, it needed to be above it as this is what the large washers bump stops etc and in-turn the body sat on... all changed and put back on the car re-attaching the r'arb and torquing all up, dropping it back onto its wheels again it was all good. Happy days.
A couple of smaller jobs next but important attention to detail. When the car went to Northampton Motorsport they fitted a new bulkhead connector. The new one was a fair bit smaller than the original so they made up a plate to size it down, however this was bare metal. I removed this, gave it a lick of Satin black and re-fitted.
Another thing to get some paint whilst I was at it was the brake duct trumpets. I had previously been working on these to go in the old foglight holes with some carbon plates to hold them. Once they had a lick of paint they were dropped into the fog light mounts.
These were re-attached to the front bumper which has now been re-mounted to the car (no pictures as it looks a state absolutely covered in dust).
Last job for the day was to re-fit the Dash2 that had come back from Race Technology. I had some rags lying around (donated baby clothes for the imminent arrival) which seemed to fit over and protect the column perfectly whilst I messed around fitting the dash to the dash panel....
I got the dash back in and powered the car up, much to my disappointment this is what I saw...
I was naively expecting it to all be working, or at least something. I have been doing a bit of research and asking around and
@neil a has been very very helpful. It looks like I need to get the dash plugged into a laptop and check/change some settings, hopefully I can find a PC/laptop to use (I only run Mac's) and then get this sorted... thats my priority moving forward...
Time is running out before the baby comes so I would really like the electrics in a good place before I get barely any time on it.
I don't want to get the green-baby-curse
@neil a @NorthloopCup ![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Unsure :unsure: :unsure:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
