loggyboy
Looks like one of these.Did previous owner build that housing themselves?
http://www.cliosport.net/threads/battery-induction-cover-all-sold.796846/
The battery/ filter cover? @MarcRDid previous owner build that housing themselves?
You shouldnt even need any extra clips, the Ramair comes with one, and the other end of the metal pipe uses the OE one.I'm confused. I've just ordered the ramair cone and a 90 degree ASH silicone elbow in red (obvs). Apart from jubilee clips, do I need anything else? I've seen others having to get joiner things?
No metal pipe. I'm completely standard at the moment.No you dont. Only need joiners if the filter and hose won't match up, which yours will. Have you got the metal pipe going to the filter?
I opted for the red silicone purely for the colour. Soo... TB > Standard Elbow > Silicone Elbow > Ramair? In which case i won't need joiners?
Got ya. Best place to order joiners?Oh yeah sorry misread you first post:
OE elbow-->OE clip-->70mm alloy joiner-->new Clip-->90degree silicone elbow--> new Clip-->70mm alloy joiner-->Ramair clip-->Ramair filter.
You chose the expensive way!
The pipe that goes into the standard air box? Yes i pulled mine off as couldn't get the cone in with it still there.Does everyone remove the air feed from behind the front wheel arch when doing this? Feels a bit... tight
Yeh that, cheers. Is the best way to just a pull it until it comes out, or is there a more delicate way?The pipe that goes into the standard air box? Yes i pulled mine off as couldn't get the cone in with it still there.
I think it's glued in to the acoustic valve. Cut the fabric with a knife and use wire snips to cut it free.Yeh that, cheers. Is the best way to just a pull it until it comes out, or is there a more delicate way?
Mine just pulled off the top of the acoustic valve. Needs a bit of muscle but it will come.
Why is the ktec louder? Does it use a bigger cone that we can't source on eBay?
