Brands Hatch 12-03-2012
After working on the car solidly, every weekend, since Jan 1st 2012 to bring it up to MSA specifications (hopefully) the time came to get the Cup on the trailer one last time....
The preparation for the Brands Hatch day took longer than usual as kit has been moved, not used, lost and generally messed about with over the last 5 months since the last track day in November 2011.
The trailer has had 4 new tyres (had a few punctures last year) and the best of the lot is now the spare, also noticed some loose bolts on the ramps. These after tightening sheared, when replacing realised that due to being loose allowed the ramps to flex. Some cracks have appeared in the metal from flexing and I’ll have to get those welded up soon. Replaced a front marker light and other than these issues the trailer seems to be all ok.
Began to give the Cup a final clean and once over, removed all the wheels, checked all nuts etc that I could see, gave the inside of the wheels a clean and put them back on, one of the rear hub nuts did tighten up a bit more, I have had the hubs off so knew to check those. All oils and fluids ok, went to start and put it on the trailer….
It wouldn’t start…..big WTF! It’d turn over 3-4 times then die…immobiliser. Stood there looking at it for a few min’s, cursing. A quick search on ClioSport for “reset immobiliser” this brought up the answer in the first post. Hold the button on the end of the wiper stalk whist turning the key….did this, dash gauges and lights went through a self-check and the Cup started on the next key turn. Great stuff.
Cup on the trailer and tied down, tools, spare wheels x 4, jerry cans of fuel it’s ready. We leave on the morning of the 12th at about 0430, thick fog so take it easy. Reach the Dartford crossing at around 0615-0630; decide to stop at the next services. Like a proper old married couple get the thermos and sandwiches out and eat a bit of breakfast. I gave the trailer a once over, straps all tight but a tyre looked down in pressure. Checked and it was at 10psi. Get the pump out with its long lead to the reach the Passat’s battery and pumped it up to 45psi. I’ll have to get the tyre of and the rims cleaned, slow puncture.
Reaching Brands, as never been before, we get totally lost inside the maze of gates etc ended up following another car across the track to the paddock area. Sam takes the Cup for a noise test, meet up with Burpspeed and go to the briefing. Then we get track side for sighting laps. I do the first 3 and Sam takes it for the next 3. Notice the difference in the cars acceleration…pulls from the start with no apparent loss or dip of power, brakes are warmed up and these are also loads better than last year.
I hop back into the driver’s seat, Sam in the pax seat, take it out for couple of warm up laps…..we both show a bit of concern at the drop from Paddock to Druids…gulp. Get to know the car, it’s performs a lot different than before, power is there the moment the accelerator is pressed and it’s all well useable. After warming up give it some stick….438 cams have totally changed the cars power delivery, it there at all times and it’s instant too. The upgrade from EBC Red stuff to Yellow stuff was a timely change up as the red’s would’ve melted for sure. Brake feel is totally different and they bite from the start, very good pedal feel and there was no concern that they weren’t capable pads.
After Sam takes the Cup out and gets to know the circuit and car, “it’s a bit different” we seek out the Burpspeed guys.
Bit of discussion later, mainly about Paddock…we try again….getting braver each time round Paddock, actually really liking Brands.
Jay offers to give me a few pointers on track, so after nearly cutting the grass (bit of lift of through Surtees) he gives me some excellent advice and track guidance and then shows me the lines driving me in the Cup. This improves things no end, I’ve got right foot hard down through Surtees now. I get Sam in the driving seat and give her the same pointers, track position as Jay gave me. She’s actually reaching 110-115 before Paddock, I did shout brake once as we pass the 150 mark…just in case she forgot…She’s getting more confident lap on lap, still a touch fast into Mclaren at times and not realising why the Cup won’t get into the inside….where as I’m maybe a touch too slow but get a better line and exit round the corner for the pit straight.
Sam has a bit of a sit down for an hour or so as the track is quite demanding and full on all the time, unlike Snetterton, Silverstone where you have ample time to prepare for most corners. Not sure if Brands was the right choice for a fist race, for Sam any way. May either let her sit it out and both do Silverstone at the end of May too. Wished we’d started at Snetterton now (both been there many times), remaining flexible and will see what pans out.
Met James, Lee (Lee PM me and I’ll send email for photos) and a few others, nice to meet you all. Though being busy didn’t really talk for too long.
Thanks again to Jay and Tony for the help you gave us.
All in all an excellent day, car was faultless throughout, apart from the temp\wheel checks didn’t have to change adjust anything.
Looking forward now to the 30[SUP]th[/SUP] March, track day at Snetterton along with our ARDS tests too.
