Twingo RS Tyres
Car  Megane 230 R26
Morning all,
What sort of tyres are people running on their Twingo other than the standard ones? I've pretty much had enough of the combination of the original tyres and my mrs, and my wallet isn't too happy about it either!
The original Contisport tyres have a tread narrower than the wheel and have an appearance of being stretched onto the wheel, with quite a pronounced rim protector that does nothing to protect the rim. What it does instead is when she does brush a kerb, the wheel gains a kerb mark anyhow but the big rim protector snags and a chunk tears out, this time the tear disappears into the bead behind the rim! This will be the second new tyre in three months and she's only had the car since November :mad:
I'm pondering replacing all the tyres with a more conventional design but wondered what people might recommend, don't want to degrade the handling or next thing will be she tears a chunk out of the car itself instead of a tyre :S
Cheers ;)
Its only the width of them. I think the standard ones on mine were 195's. I got some 205's and the stretch wasn't there and it handled much better.
Stick with the conti sports though, they are great tyres for that car.
Yeah exactly that's the problem, I was thinking 205's would be a good idea... cheers for the advice Craigus :D
Am I correct in thinking 205/35 for the same rolling radius as 195/40?
Update: actually ignore me 205/40 is the closest to 195/40 :)
How about pe2s? 205 profile with rim protectors & they last pretty well.
The PE2 is possible I had those on my Trophy, not sure how readily available they are in a 40/17 though, the Clio took 45/16...
Those hankooks are a cracking buy. I'm guessing you can't get conti's in that size.
195/40 is a pretty rare size tbh, best going for a 205/40 as there is much better choice and its a much more popular fitment so should be a fair chunk cheaper.......
if you fed up of front lasting less than 8k then i would get a harder compound like a pe2 or somthing similar.....
toyo t1r/hankook evos are about £75, pe2/prada about £100, eagle f1s about £90, contis £110
all with mytyres.co.uk
