Had a bit of an early morning today!!
Since fitting the 2118's the car has been sitting a little high so I woun the coilies down so it's now lowered nearly 70mm! The rears were an absolute pig to do
Before...
After....
Sits quite nicely although I hope it does not get any lower after it settled a bit, front splitter is only 3.5 inches from the ground!
Whilst I was at it I also fitted these
Will have to see how much of a difference they make, the originals didn't have much life left in them!
Also have to car booked in on the 31st at Jamsport to have a whiteline Rear antiroll bar fitted and then full alignment done, as it was guess work with the camber bolts this morning! I have a set of rear camber shims that I may fit prior to that. Was thinking of running 30 minutes rear and 1 degree at the front. Would that be ok for a road car??
