182cup & 172 racecar
Yes, that's what caught me out! None of the shown circuits are the one we used, I was following Ian and wondered where the fk he was going.
I'm trying out some 50mm corrector pins in mine soon. Just the steering arm correction to do, but I'm tempted to leave it at the current ride height and just use the pins to gain more RC correction.I'd say that was even better than horizontal as the line is from the centre of the inner bushes to the centre of the uniball and the bushes sit a lot higher relative to the bottom of the wishbone.
looks great at that height, the wishbone the shaft and the track rod all almost parallel just HAS to work well.
Usually nut to back Pete, not that it matters that much.
Glad you got it sorted now, I did have a chuckle though.
Mistakes, we all make them.
You should stick to cutting grass Pete, Only jesting,
Glad you got it sorted, and real shame I missed out on these
Pete - bin off the 25mm spacers and replace them with either 10 or 15mm spacers at a push. The 25mm ones will ruin your scrub radius and you won't get the full benefit of the hubs. Remember the new bottom ball joint holders push the wheel out 5mm over standard and the cup is already widetrack from the factory.
Nice - liking the look of that!![]()
Nice, be interested i hearing your opinion on these.
No, sadly not yet mate. Slight setback due to unforeseen and unavoidable circumstances but I'm still hopeful it will be going for mapping within a matter of weeks. Once I get it done I'll report back with some temperatures and suchlike.Cheers, had yours mapped yet as interested in your running engine temps after a bit of hard driving!
Looks good Pete.
Have you planned which races you're doing next year?
Will you be doing trackdays etc in the car as well, or just those 5 dates and a bit of testing?
Seems a bit of a waste to have such a cracking car sat there and not use it more than a few times a year each like that reads!
Pete, I will keep an eye on here for the track day tester, may pop along.
What's your wheel offset pete?Cheers Mark, will do. I've a pair of 15mm's, that I took off the rear, in my box of bits. Will get them on this weekend.
The pins fit between the hub and the wishbone and give a greater amount of correction.Where would these pins fit?
If it's ET 35 your possibly better off with 10mm spacers then Pete, but give it a go on the 15mm spacers and report back.ET37 (or 35) on all my wheels - TD 1.2's and Oz Ultra's
Yes, that's about it - those 5 races in entries alone will cost £1650 add on the rest and we're talking 5k +. We're a family and do lots of other things - off in August sailing in Greece for two weeks, Easter holiday planned and plenty of other stuff that Harry and Scarlett do at weekends football, swimming, horses, homework, it's not all about the car but it's up there. We did plan more last year but in fact did less for one reason or another, not really a waste as I'd rather have 1 quality session than 2 or 3 mediocre runs flogging a dead horse - so to speak.
What offset you running Tony?I've just ordered my 15's, had to get some crappy Halford ones 9.5+5mm so I could just put the wheels back on, as they were rubbing on the springs.
I'm not sure what offset the f1's are so I'll take your word for it, but ET43 with a 15mm spacer is fine. Just as well eh! LolStandard f1's, 43 I think. Does that sound about right?
I've just spent the last few evenings staying up late reading this thread from the start.... Very impressive Pete feel like I know you quite well now as it was like a life blog... Really good read... Love the way you've just jumped in. It's certainly inspired me to get involved so thinking of converting my Williams shell and racing that.
Awesome Pete will be good to see you at Bedford![]()
Are you and the wife coming out to play (I mean "test") on the 15th Pete?
Nice one Pete, glad to hear the fires burning again
without going through your thread, what exhaust are you running?
