Been a while since I've updated this thread so here's what's going on with my ep3 at the minute .
It's been of the road for about 3-4 months now I've basically replaced all the tired bushes ,ball joints and anything else that could do with changing , whilst also adding some mods too , but nothing over the top just to tidy up the car.
First job was to replace the steering rack slider if anyone knows the ep3 this is common problem with the steering rack , the part is made of plastic and as it runs in a channel it's wears down on the sides causing the "vague" steering and lack of feel . Replaced it miles better now greased up the rack too as that was bone dry .
Next job was to refurb my tired looking rocker cover once again another common problem the crinkle red paint starts to crumble and makes the bay look tatty so after stripping it down with nitro morse and assorted sanding tools it's was sent of the powdercoaters , got it back and it looks awesome . Well worth the £20 also replace the gasket and the spark plug o ring gaskets .
Also added a Mugen rep oil cap
Then I replaced my gearbox engine mount for a powerflex item as mine was very worn giving me a sloppy gear change with this now replaced miles better changing gear
I then bought an exhaust system , I went for a scorpion catback system that came up locally got it for £100 which was a bargain , but wanted somthing with a 2,5 inch bpipe , so sold that on for £200 so made money , an m2 racing backbox came up for sale on ctro very cheap so bought that for now mated to the oem bpipe Intil my area Motorsport silenced bpipe is made ,
Here's a pic of the scorpion system and the m2
Replaced my aux belt also as that was due to be changed, stopped the squeal on start up once cold .
Painted my caliper red and the disc centres black
Under sealed and cleaned all the arches cleaned up brake pipes and greased .
Under sealed all slam panel and cross members
Cleaned the aem cai air filter
Refitted bumper properly and aligned headlights properly
Replaced track rod end ,bottom ball joints , link rods.
Wanted to tighten up the rear end so bought myself a Jdm arb for a steal of £40 these usually god for 60-90 so happy with that much thicker than oem , 18mm oem , 22mm Jdm replaced the drop links for heavy duty Meyle items again a lot more heavy duty with a 4 year guarantee too so good deal for £35 for the four .
Also got myself some hel braided brake lines the ep3 brakes are far from the best and the clio was far superior in terms of braking , so my aim is to get it to perform aswell as them so new lines and fluid just waiting on a set of ferodo ds2500 pads to finish it off already have nearly new brembo hc discs will get a brake stopper from Tegiwa too .
Car should be back on the road Monday hopefully , not a lot has been changed but hoping it will perform a lot better than what it was
will try update this more regular for those who are interested
Cheers dan
