So got a few updates, been a bit lazy and only really been updating me RSmegane thread.
So first off I got round to replacing the front discs
Soon stripped the old knackers off
Gave the hub a bit of a clean
New disc in
And all went well other side and are nicely bedded in now.
If you remember the trouble I had with the downpipe of having to grind out excess weld and re-weld it from the rear to fit.
Well I got onto Whybee and they said they had a new modified downpipe which they happily sent out, can't fault there service and I will fit this sooner or later
As you can see the lip for the turbo is there now
Then on to the rear brakes
Old setup
Stripped
Old discs well past it
New setup all fitted and looking much healthier
Also I fitted some 5mm front spacers as the rim protector on tyre would just catch on coilovers on full lock, something that seems common on coilovered meganes
Either way it's done the trick.
Next up I wanted to raise the rear as it had settled a little to low for my liking and and I like a bit of rake.
Also adjusted exhaust has it was a little close to the rear bear and would vibrate and knock time to time.
Then yesterday the final piece to the puzzle finally arrived
Siemens Deka 630cc injectors
Is booked in with Paul at RS tuning on 5th of March for mapping, hopefully see around 285bhp and torque limited to 300
