Jacob's Inferno 225 Cup
Think that's the trouble mate, finding a well looked after one. Both of my clios are spot on (touches wood). Sorted the slight misfire on the cup and it idles spot on from cold. I expect if something nice came up I'd be tempted.
Anyway I digress. Keep up the good work :)
In bits. 😂
Waiting on a 3" de-cat pipe to be made then its off for mapping. Had to replace the fuel pump, 3 pot boost solenoid, K&N panel filter, fuel filter and cooler NGK plugs and a few other bits.
In bits. 😂
You're handy with a spanner. I am not. :(
It's a good spec mate.
Wish our mechanic in work was handy with a spanner. Did the leads and plugs on my car and managed to cut the inlet pipe so it was idling at just under 2k lol.
Just picked the 16t back up from midland turbos, they've been extremely quick And mega helpful and done a fantastic job.
Powwwwahhhh
Right tailpipes dribbled a bit there.
Does it feel solid with that kind of power or more raw on the edge?
Evo triangle
So filled up this morning at 07:00am with v-power and by half 2 I was running low.
Met @notnormaldan and Steve at etwall services, then @steburns joined us further along, along with a guy in a 265 Megane.
We all drove to the ponderosa cafe had some brekkie and got on with finding the triangle.
Such a great run out.
But today I properly found out what my Megane was capable of, bearing in mind that I have no lsd and vredestein ultrac sessanta tyres.
My god it shifted, a little nervous and getting used to the new brake set up / still bedding the pads in and used the roads, soon as everything warmed up the Megane was faultless. I even turned traction control off (badmanz) and let it have it, the car just soaked up the roads at crazy speeds and never twitched, felt a little slide in some sweeping corners due to no lsd but I've not got a bad word about it.
Just drove and really enjoyed it.
Need to push harder next time and get @Gray holding on to the s**t rail.
Are you running standard internals mate?
I'm running 225 pistons and I hear they're not very safe for much over 300hp depending on the mapper also.
I think the 1*2 rods are the same as the meg rods too although I may be wrong, this is why scoff kept the torque relatively low on my 182 turbo.
Jacobs running forged rods iirc
The *safe* limit people run the Megane internals to is 300hp / 320ft.lb... But this is always a gamble, I've known standard cars throw a rod or crack a ring land.
The rods are practically the same, yep... so they will bend if you push them :smile:
Jacob has Manley conrods fitted, with standard pistons, so it should cope with the extra torque.
Thanks for that :)
My rods should be quite safe then as im only running 250ftlb.
Looks like you had a good day, brilliant roads around there too. The cattle grid always catches me out on the Evo Triangle though lol.
Not much of an update.
Drove it a little, thought about selling then drove it a little more.
I think I'm ready for something else[emoji53]
Looks great Jacob, but I didn't realise till the other day that the seats were blue! :tongueclosed:
Thought about changing them but they've been in the car since being built and look brand new still so kept them in.
Going to put it up for sale shortly I think.
2006 (56) Renaultsport Megane 225 cup.
Spec;
RS tuning stage 2 remap (287 bhp; 325 ftlbs
Manley forged con rods
ARP bolts.
Ktec FMIC
Ktec 2.75' cat back exhaust
Forge actuator & recirculating valve
Samco boost hoses (black)
ITG induction kit with enlarged cosworth filter.
Rstuning 3' decat
630cc injectors need fitting.
Lowered recaro subframe mounts, waiting for custom graphics for the sides.
New tre's.
New twist links and stabilisers.
New tfd steering rack bush.
Goodridge braided brake lines
R26.r headlights
R26 shocks & cooksports springs.
Carbon fibre R26.r spoiler
55w 6000k HID kit
Alacantara A pillars
Brand new red brembo calipers, with hc disc and ds2500 pass along with rbf600 brake fluid.
Fully powerflex polybushed engine / gearbox mounts.
Serviced last month with millers nano drive oil and new spark plugs.
New windscreen start of August.
Sat nav Gps and DVD player
The car now drives effortlessly smooth after changing the twist links and rack bush, everything feels tight and perfect.
I've looked after this car and it's been well looked after before me.
Looking for £5600
