Update
As with most weekends, its the only real time that i can get anything done on the car. Pretty much 2 steps forward 1 step back today.
Brakes
Recieved my order of some ATE supergold of George yesterday. As above, i have recently changed the discs and pads so only made sense to complete the puzzle and do the fluid. Overall the fluid wasnt too bad but might as well change it now as already bought the fluid.
Started with removing the engine cover and using a syringe to take the fluid out of the master cylinder. Made use of my new £12 light as i couldnt see sh*t in the engine bay
20150912_095834 by
felixta22, on Flickr
20150912_101411 by
20150912_100352 by
Then a couple of pics from the process and the fluid i removed. Luckily all went pretty smoothly, was a little concerned about the bleed nipples but they unscrewed fine.
20150912_121056 by
20150912_112739 by
Centre caps
As you may or most probably not read from above, got 3 turini centre caps that i planned to fit onto my new wheels to make them look more oem. The main hurdle was matching the paint, the seller didnt know what colour they were but i for some reason i dont know had a can of Rover metallic grey in the garage which turns out is only VERY slightly darker of a shade than the wheels so i used that. Finished spraying them yesterday but i couldnt secure them to the new wheels so just got the hot glue gun out and stuck them on. They definatley aren't going anywhere and look much imroved to me.
20150912_141113 by felixta22, on Flickr
20150912_141120 by felixta22, on Flickr
20150912_151423 by felixta22, on Flickr
Handbrake
I noticed the other day when i had to stop when going up a steep hill that when i put my handbrake on i still roll down the hill
. So i looked into how to tighten it and how much and was told the handbrake should be fully on at 4 clicks, well mine was on at 9
. So i tightened that, not very exciting tbh but it is another thing i did to the car.
20150912_132436 by
Cambelt
I also started purchasing parts for the cambelt job :unamused:. Recieved my order of some new coolant for when i do the waterpump. In the post and on its was to me also is:
Some Elf engine oil - for when i do the dephaser
Sump plug & washer
New coolant bottle
Oil filter
That just leaves the big ones. Cambelt kit, aux kit and renault tools. WIll buy all this once i have sold my 182 alloys.
20150912_141429 by
Also gave the car a quick going over with some QD just to remove some dust and water marks. The sealant is doing its job as normally the car is filty after a week of backroads to work, but this week it was suprisingly clean.
Tomorrows job is to test fit my sub back i the boot, i haven't re-fitted it since i removed it from my 1.2 as i love the boot space too much but i do really miss the extra bass it gives. May invest in a under the seat subwwoofer but cant find a 2nd hand one anywhere.
