I seem to be building quite the pile of parts! I will update properly when I get chance but today I started work on turning my aluminium gearstick shaft.
Taking inspiration from the BMS and the PMS shifter I've decided to make my own. How hard can it be? I have a few ideas for stiffening up the shifter and I have already bent the scenic one that i got cheap as I mentioned a few pages back.
I'll be using a quiafe style knob and documenting what I do as I get chance.
Started off with some 22.2mm x 3.25mm WT (£5.96 posted for a 400mm tube, enough for any mistakes) and turned it down to 18mm OD.
I parted the ally at 170mm, and left a ridge at 145mm where I'll be having the lift up collar. I'll be getting some large penny washers for this and having a play with what feels best to get a grip onto.
A slot needs to be milled lower down the shaft to allow the reverse to actually work. This will be tomorrows job if I get chance.
Couple of pics for now, but obviously a long way to go.
