It's doing it everywhere annoyingly. Wheel sat straight and it goes left. Tested on motorway, straight roads etc and it's the same. I had similar when I had those cambered spacers on the back but you can see how straight the rear is now so it should be fine.Glad that everything went OK at Bram mate, strange that it's still pulling to the left, could maybe to do with the camber of the road?
Does it scrape now, looks really low? If anything, I'd just raise the back a touch for a bit more rake.
I only scrape on full lock very occasionally but it's only touching on where the lining bulges. I'm quite happy with the height, rear can't really go higher as there's no inbetween. Either that or I stack 2 rubber pads on top of each other.
Can see the rake most in this photo
On some of the hilly wales roads my front did scrape, but to be expected!
I'm not sure. If I get it rechecked and it's still all spot on then it must be something else. Like I say sliders were all changed and greased up last year and id given them a wiggle recently and seemed like they were free. Front bearings have also been changed alongside wishbone bushes so won't be that.That's weird, can't be to do with the alignment then? I'm sure Brad will be able to have a poke around and see if he can find anything though.
Yeh, looks spot on in that pic. It's like my car, sometimes I think it sits bang on then most of the time I'm not happy with it, hence the want for them Cooksports haha.
Daniel told me to check my rack bushes so I'll do that on Saturday morning, unless I can do it without axle stands?Alignment looks bang on! One of the straightest i've seen.
How are your tie rods and ends and rack bushes?
I think so! I've nothing else to compare it to. Often want someone else to give it a drive to compare to their own car!Usually get signs of wandering steering if it's rack bushes tbh.
Is the steering nice a tight/precise, just that it's pulling to the left?
Ill get brad to maybe have a look at them. I doubt they've ever been changed in 127,000 miles
They easy to change?Doubt mine have in 96,000 either!
20180216_160233 by Louis Walker, on Flickr
20180216_160244 by Louis Walker, on Flickr
20180216_160250 by Louis Walker, on Flickr
20180216_160258 by Louis Walker, on Flickr
20180218_133538 by Louis Walker, on Flickr
20180218_133543 by Louis Walker, on Flickr
20180218_133556 by Louis Walker, on Flickr
20180218_133606 by Louis Walker, on Flickr
20180218_154012 by Louis Walker, on Flickr
20180218_154037 by Louis Walker, on Flickr
20180218_154110 by Louis Walker, on Flickr
20180218_154149 by Louis Walker, on Flickr
20180218_154122 by Louis Walker, on Flickr
20180218_154050 by Louis Walker, on Flickr
20180218_153814 by Louis Walker, on Flickr
20180218_153727 by Louis Walker, on Flickr
20180218_153805 by Louis Walker, on Flickr
20180218_153744 by Louis Walker, on FlickrThanks mate. I'm after a smaller suede wheel really!Looks fresh mate.
What wheel you thinking? Got this going cheap if your interested? View attachment 1356913
But they're cheap when imported (350mm) and look decent!330 imo
Ok bud, no worries. Was just a Oem option,Thanks mate. I'm after a smaller suede wheel really!
Haha, it was Yeah! From Halfords I believe when they were trialling the auto finesse stuff? I didn't try the all in one polish but might be decent if the other two are anything to go by.This looks better and better everytime you post some photos @Louis great stuff.......... reading what you've been using, didn't get this kit did you? :wink:
I used the shampoo and spray wax for the first time yesterday, very pleased with the results also!
As for the steering wheel, I agree with the above, 330mm is an ideal size IMO but if you want black and suede, what about the Sparco one I have as an alternative to the Renault Sport one? The suede actually suits the colour of the seat fabric better than this photo shows;
Your interior looks great now Steve! With the PMS shifter it finishes it off nicely to be OEM+, I'd read you had that rattle but hope your elastic band fix stops it :wink: you happy? Sometimes you feel like you should be just because you spent so much money or time doing something but then you're not really if that makes sense haha.
What steering wheel is that? 330mm?
I'm the opposite, I really like the flat middle Haha! I might have to compromise and get one with a horn.Cheers mate! Yes I'm really happy with the interior now, all looks spot on just as I want it :blush: you're right tho, when you really look forward to something getting fitted and then you're not happy, so frustrating! The rattle is a good example of this! But hopefully my little bodge will help the issue. That's my thing, I like the upgrade parts but don't want added noise or to loose any comfort
The steering wheel I got from Demon Tweeks, yes 330mm and black suede. I just think the centre horn push finishes it off, not so keep on the flat middle on the Sabelt personally, looks like something is missing!
You still on a building site?I should have come to yours and you could have done mine as well![]()
I gave the bonnet a going over before I fitted it, but the rest of the car I did way before Christmas. I was going to do it yesterday but got carried away doing the interior then it was too late. It's changed a fair bit since csfLooks shiner every time you wash it Louis. Did you hit it with the da yet?
:mask: would have been 11pm before I got inI should have come to yours and you could have done mine as well :smiley:
Bummer, get some ceramic coating on it for protection. We had the same when we moved here, I don't know if the winter mud or summer dust is worse?Yep, and they'll be building for at least another year yet as well. So long shiny car!
Cheers mate! Appreciate the kind words. Not sure if there's going to be any meets soon? @rvCar looks awesome as usual. We all need a big meet up or something. Can i still come in my Accord haha
Thanks againAs said on WhatsApp. Looks great. You'll 100% regret a 350mm wheel and I'm posting this to requote when you buy and change your mind a week later.
Good choice, I know a guy with a sexy haircut who's got one and he likes looking at it as the car isn't mobile.Cheers mate! Appreciate the kind words. Not sure if there's going to be any meets soon? @rv
Thanks again :wink:
Yeah I know you're right. Was looking at the oreca turnone ones yesterday
If I got one I would change the yellow band. Might lasercut one of those button plates with an engraved fake horn. Similar to this but might even turn a steel one and spray it... Not sure yet. I'm just not a fan of the horns!Good choice, I know a guy with a sexy haircut who's got one and he likes looking at it as the car isn't mobile.
standard wheel gang330 OR GTFO
Only if you wash it in the bath for me when it gets dirty xThese brothers know.
I've had 300mm, 320mm, 330mm, 350mm and the standard bus wheel (380mm) so listen to us.
So 330mm yeah?
