14-09-2017 Spacers on front Axle
I wanted to get my stud and nut conversion onto the front axle as well having being running it on the rear for months. However the issue was to run the setup I either needed to buy smaller studs or run spacers. Man maths said spacer time!!!
So fitted the studs, slapped on some 15mm spacers and then had to dremel the arches down to get the things to fit as the front track is now wiiiiiiide!
reason I needed to do this was the Speedline Maracanã wheels have centre caps that cover the wheel bolts, and the studs as they were would be too long to get the cap on. And I have to run these wheels as I like the fact the car has its sort of original look from the outside.....ish!lol!!!
anyway, pics, arch with the lip, the fronts are plastic like the mk2 so easy to cut down
the tool for the job
and all fitted, they are very close and catch on manoeuvring on uneven ground or full lock, but the car feels incredible now, I stiffened the front shocks to 13/19 so can go stiffer but works for road and I can stiffen fully on track.
I will also more than likely remove the front spacers when running track wheels as they are 7J and the slicks are more like 205 equivalent so suspect rubbing with the spacers on may be more of an issue.
anyway (again!) pics!
and had a spin out with
@dann2707 to test the setup, seemed decent enough and he grinned a bit
cheers
Ben
