Finchspeed 172 PH2 trackday car
List of jobs I Know !
Install New rear Lamda sensor
silicone paste on exhaust decat to centre section.
Numerous ABS fault lights , possibly sensors on rear and rings up front or both !
New oil and Filter
New Front discs
Rear Boot lock doesn't lock , Solenoid maybe ?
New bonnet catch for slam panel required
2 front tyres for OZ alloys required
Install Harnasses
New wiper Blades
Check Torque on various bolts
Install AST Solid Topmounts
Purchase Rear Camber Shims
Full alignment
Paintwork is in a mess , laquer peel on roof and passenger rear quarter , not sure what to do !
Paint wing mirrors orange and track alloys.
Clio has been abit of a storage unit !
Started on the brakes today ! Car hasn't moved in a while so I stripped the rears first to clean up and regrease slider bolts.
Install New rear Lamda sensor , Wrong one turned up !
silicone paste on exhaust decat to centre section. Done
New oil and Filter
New Front discs
Install Harnasses
New wiper Blades
Install AST Solid Topmounts Done
Full alignment
refit Seats Done
Front & rear brakes removed , greased and refitted Done
Both seats now back in , Just need to fit my harnesses which are currently in the Nissan !
Steering wheel needs some dye !
Excellent build! How close is it to being up and running? What wheels are they, look awsome.
Hopefully be ready next month. Just need to fit aerocatches and my harnesses and then need full alignment doing and shakedown as it's been off the road for a long time !
They are some of the best looking wheels I have seen on a 172. They look spot on as does the rest of the build.
Installed aerocatches , never again !
Alignment was slightly out on one !
Broke a bolt trying to adjust the bonnet!
Ohh.. I quite like those wheels. You've gave me ideas now.
If you're ever tempted to cut your rear bumper, I'd gladly swap you (with cash your way) for my iceberg bumper that already has a cutout.
Abit more work done on the clio tonight while we still have decent weather. Got some fault codes to clear.
Majority are airbag related but think I may have a dodgy rear caliper too!
1428963
Boot lock had never worked , I had tried another solenoid with no joy , found a couple of snapped wires in loom which I repaired then re-routed, still no joy , had another solenoid spare swapped and all working , yay .
Any ideas what to do with the roof , the laquer is destroyed, roof and really rough ! Could this be revived easily ??
1429003
1429717
Installed some new slider pins on front calipers. still have the issue with the brakes , air in the system. Waiting for a mate to come round and bleed the system then try bleeding the abs pump.
Actually got it motd as I need a car to get to work in while i do some work on my daily !
Jesus the induction kit is noisy 🙈😂😂
