Is that actually crimped? As tbh the lug doesn't look like it has any crimping tool marks on it?
Damn... is that the positive from battery? Or to Cartek?
Yes it was crimped but the particular terminal I used there had quite thick walls and the crimper needed a bit more pressure.
Solder attracts moisture and corrosion mate.I always use solder on terminals. Crimp then first then a dab of solder.
62 -1 from memory mateAs you’re on here can I ask you, do you know how many trigger points the speed sensor in the gearbox has? Assuming it’s an inductive sensor (Which I’m pretty sure it is)
Trying to configure wheel speed in the Emerald!
Thanks Mark.62 -1 from memory mate
No problem buddy. ??Thanks Mark.
Fishing line is an ideal "string." Tensions very easily with a small weight tied to each end and very cheap.
Thanks for this. I had to brush off the old trig skills at the weekend!Get some of the fluoro yellow sea fishing line, it's nice and easy to see.
I did a sticky thread on here which has an online calculator that you can use when doing the string method, just input your measurements and it'll tell you what the toe is.
https://robrobinette.com/DIYAlignmentCalculator.htm
Sorry to hear the bad luck. Hopefully it’ll be easy fix.
Thanks mate. I'm staying positive!saw this on facebook, right pain in the arse rob. hope you can get it sorted!
Thanks mate, me too.Sorry to hear about the engine. As others have said, hopefully a quick fix and back on the grid for the next round.
Some threadlock on all the trumpet bolts now then too. Hindsight is a wonderful thing isn’t it.
What does your car weigh now as I thought you had quite a bit of weight out of it but you say there is another that is considerably lighter? What does his weigh?
I estimate mine is knocking on 870kg, but I have yet to fit fibreglass doors and boot. Tom's shell was dipped before he built it so all seam sealer and stonechip was removed. He's got an alumium flat floor in the boot and of course fibreglass everything.
He even uses an alternator out of a JCB to save weight!
Don't know how light it is though as he plays his cards very close to his chest.
I do know my engine makes more power but there really is no substitute for weight saving.
That sounds about right. I'll get mine on the scales once its back together.Apparently my shell is 850kg with fibreglass boot l, bonnet, doors, manual mirrors and no dash ??Yet to check it out my self but pushing it in and out my garage I can defo tell the difference to me Cup shell ??
Good update, although sorry to hear of your pain.
Are you located in the South East?
Thanks.
Yes I’m in Hertfordshire, just outside Hertford.
Yes, weight is most definitely the enemy!Ah man, frustrating on the engine and as said super unlucky. Interesting way to look at it in that it may have been for the better as you lacked wet tyres and wipers (the lack of wipers made me chuckle...) I hope you get it sorted with minimal costs/ease mate.
Interesting to read about the competition and the weight differences too, then to hear different peoples weights...
Mine SHOULD be similar to this hopefully. It does feel very light but I have no idea what it will weigh. Need to get it weighed whilst it is at Northampton Motorsport
