Valve clearances slightly tight on exhaust valves?
Checked the valve clearances on my Toyota 2ZZ tonight and the results below.
Intake range - 0.08-0.18mm
Results - 0.13 - 0.13 - 0.10 - 0.10
Exhaust range - 0.22-0.32mm
Results - 0.16 - 0.20 - 0.25 - 0.25
So should I re-shim the 2 out of spec exhaust valves or just leave them be?
Is that clearance between the piston faces and the valves??
If so, 0.16mm is not a large amount of space in reserve... lol (Is there such a thing as 'valve bounce' at high revs??)
(But then 0.08mm seems ridiculously tight!!)
You measure the clearance between the smaller, low/medium speed cam lobe and needle roller on the rocker on the 2zz.
