The new tool thread
dann2707
pls dont hate me. Been looking for a very very cheap welder (ideally ARC) just for very tiny spot welds etc. We are having the Mexico back from the restorers and I can just see us needing to do a couple of tack welds on bits.
Only £30. Thoughts..... 🤡 :poop:
https://www.amazon.co.uk/dp/B097MTFQ77/?tag=cliospnet01-21
30 is a bargain but I feel it might be one of those purchases that you massively regret the moment you plug it in lol
Sir Nancy Flowers
  M140i
That was my gut feeling too. Especially as I did some research on how much even a decent arc welder is....:oops:
For how much I use it, I might take a punt. I just know we are gonna get to a point that we are gonna need a welder. Even for the exhaust or whatever just to tack stuff in place. I'm no fabricator but even being able to tack something in place for then a welder to tidy and properly weld is going to be super handy.
botfch
  Clio 182
I wouldn’t bother if you want to weld exhausts or anything thin it will just blow straight through the metal and make a mess.
Sir Nancy Flowers
  M140i
Yeah, further reading did say that tbh. I know it will have its limitations. Lots of the exhaust bits are silly thick though so im sure id be fine. Its more just a toy to play with tbh. Never done any welding so it could go very badly but how hard can it be, right? 🤣
dann2707
Would recommend a cheap Clarke unit for starting to learn. Can be picked up dead cheap nowadays.
Check my welding thread in the general chat section bud.
Sir Nancy Flowers
  M140i
I will do that! Ta!
I do have an engineer father in law who is pretty handy with a welder so I might get him to teach me ;)
OEM Battery Nonce
I will do that! Ta!
As for how hard can it be? Well it depends on the kit.
A cheap welder will be less precise and make things harder. No need to go balls deep on something mega, but I'd definitely be looking at second hand on marketplace or ebay first.
Flob
Tis £75 now!
We bought a relatively cheap inverter MIG, TIG, ARC welder last year. Its been great, loads better than the little Sealey we had before - most of the improvement is in the wire feeder which makes life really hard for a terrible welder (ie, me). I would suggest doing £150 on an inverter welder, or some more expensive ones also have plasma cutter functions which I could see being dead useful.
PS, unless you have a spot welder, MIG is dead nice to do spots with while arc is dead horrid. (y)
OEM Battery Nonce
Darryl_1983
  RB 182 Cup
Anyone ever used one of these? Popped up on an advert earlier, I know it's a leaf blower, but wondering if it'd make a decent car drier?
Edit: just realised I'd need the M18 version, not quite so cheap, but quite a bit more powerful.
Krarl
Brigsy
  T.Turbo
Ive been looking at the same stubby ratchet spanners. Ideal for occasional jobs and cheap enough. Us pro stuff is alright too, ive got a few bits and no complaints.
Andy_con
  clio 182
i need to finish the hand rail on the stairs, they need a cap. got this cheap cutter on ebay, 9.5m dia with 1/4 inch shank, cut length of 56mm :ROFLMAO:
i suspected lots of chatter and i was right, gave a really s**t finish. smashed f**k out the wood.
im going to have to make something using a more manual approach :(
thecrim22
  various
Treated myself to one of these as theres a couple of intercooler pipes on the skyline that ive found are only straight ends after popping one off
Brigsy
  T.Turbo
Bead roller looks good. On alloy pipes the molegrips with welded exhaust clamp/penny washer works well for a cheapy. Ive had 28psi through my hoses and nothing popping off.
1/2 router is king from experience @andy_con i used to always use trend cutters when i was on the tools. Still need to take a little bit out at a time though.
Long reach milwaukee 3/8 fuel ratchet has arrived. Not used it in anger yet but seems to be a nice bit of kit.
Flob
