The Bandit | Monaco 172
TheBandit
  Monaco172, Green1.2
After lurking for 7 years I have found myself in a position to do something stupid with my money. I could invest in a OEM spec Clio, keep it tasteful and sit on it as an 'investment'. Or buy something outrageous and hopefully have a lot of fun...
The spec sheet is on the forum from some old for-sale posts but to recap:
Interior
Genuine RenaultSport Recaro Trendlines
Sparco Suede 300mm Steering Wheel and Momo Hub (Fitted with resistors, so no airbag light)
Retrimmed Gearstick Gaitor (Snappy)
Genuine RenaultSport Clio 197 Gear Knob
Adjustable Stiff Shift 3.0 (Yanoo)
Exterior
Genuine Clio V6/Trophy Rear Spoiler
Sprayshack Smoothed Door Bullets (Monaco Blue/Anthracite)
Wheels/Tyres
Clio Cup Speedline Turinis (Anthracite)
Wheel Stud & Nut Conversion Kit
Engine/Transmission
Port-matched Inlet Manifolds/Gas-flowed Throttle Body (January 2016)
438 Fast-Road Cat Cams (Engine Dynamics - September 2016)
Low Temperature Thermostat (Engine Dynamics - September 2016)
Full Dyno Custom Remap – Printout for 187.6 BHP/161.8lbft torque (Engine Dynamics - September 2016)
Brakes
Renaultsport Clio 197 Brembo 4-pot Brake Calipers (Red)
Brembo 300mm Mounting Bracket Kit (Pure Motorsport)
Brembo High Carbon 300mm Brake Discs (Front)
Suspension
Bilstein B14 Coilover Kit from Pure Motorsport - December 2017
Pure Motorsport Solid Top Mounts - March 2016
Whiteline Rear Anti-roll Bar - March 2016
Powerflex Bushes (Wishbones, Front ARB, Steering Rack Mount, Rear Shock Upper Mounts, Engine Mount Insert, Dog Bone Inserts, Rear Axle) - March 2016
Eibach Camber Adjustment Bolts – March 2016
Exhaust System
182 Exhaust Manifold (4-2-1)
Custom 182-Style Cat-back Exhaust System (Built by Fast Road Conversions - December 2016)
From the receipts most of the work was done in the ownership of Tony White (if that name means anything to anyone), I bought from @Louis1979 after his own good few years of ownership. If you are reading this, thanks man - it was a pleasure meeting you, I will take good care of it!
The seats are shockingly comfortable, the engine feels amazing and the exhaust is far to loud. I love it.
Initial work in my first month of ownership includes full Cambelt/Dephaser/Water pump service, tracking, AC Re-gas and headlight polishing at Two Techs. Followed by Rainsport 5s all round and new Brembo Pads for the 4-pots.
MOT said pad material was running low...
Being a retrimmed Snappy Gaitor I didn't want to replace it, so out come the self tappers:
After Re-gassing, the A/C would only blow hot. A broken gear under the dash was the main suspect. F*cking difficult to get to in a one car garage, but I am still young enough to form myself into a sort of half-pretzel. One 3D-printed housing later and the cog is strengthened and the A/C is blowing cold once more:
There is so much more to do, but at least its a start. I want to thank the forum for all of the useless useful conversation over the years. And may you continue to talk s**t be an essential resource to the community as a whole.
If you can recommend any paint shops / wheel refurbs / dent removal in Somerset it would be much appreciated - Thank you for reading
Dicky Belly 2
  Mk1 Audi TT 3.2 V6
I must admit, I love a good Monaco, and I really like the 182 rear pipe conversion that will upset the purists.
T12
  Monaco Clio 172
Yeah that’s my old car, and I’m the Tony White you’re seeing on a lot of the paperwork/receipts. Most of the modifications were carried out during my ownership, but unfortunately I failed to keep the project thread up to date at the time.
The car was absolutely fantastic during my ownership, and I would have held onto it if not for a house purchase forcing the sale.
Enjoy it mate!
Any questions, feel free to shoot me a message.
TheBandit
  Monaco172, Green1.2
The 2118's look amazing, hopefully I can get through the other hundred things that need doing and get the brembo brackets shortened to fit them
TheBandit
  Monaco172, Green1.2
Will probably sink a silly amount of money in and end up doing the same in a number of years... But that's a problem for then!
Appreciate you dropping by, will give you a shout if anything a comes up - appreciate it
  • Like
Reactions: T12
TheBandit
  Monaco172, Green1.2
Time to look over the car while its off the road for a few weeks, interesting....
Also interesting...
If anybody has sources to replace these plugs please give me a shout
Also the clutch fork boot is loose, I wonder how much old oil has made its way in there
Oh well, time to get the bumper off. Great...
Airbox out. The right pipe is broken and the underside was floating in the bay
Replaced with a fatty induction for the lulz, feels like a right of passage. Will either fix/adapt the pipes for the original airbox or get a Proram cone if I get on with it.
Autistic Acoustic valve removed, carbon canister removed
TheBandit
  Monaco172, Green1.2
Headlights out. The left headlight had a popped out adjuster but I replaced it anyway. The right side adjuster had blown into 12 pieces as well as the middle pop mount out of place... As there are mismatching bulbs I can only guess someone had a real hard time trying to replace the bulb while the headlight was still in place.
I found silicone spray mega useful to pop the difficult middle one back in. The left headlight adjuster had cracked right ad the ball. Managed to get the mount out with a pick. I drilled a hole in the ball and run a self tapper through to turn it to dust so I could replace.
Something easy for a change
I knew the tab at the back of the block was close, seeing it on my own 1*2 for the first time doesn't fill me with confidence. Angle grinder coming out when the next opportunity arises. Still plenty to do, thank you for dropping by
TheBandit
  Monaco172, Green1.2
I might have a couple of those plugs on a spare loom I have
You acoustic valve🤣🤣
Let me know if you do and what you want for them. They obviously still work... for now.... Will have to play the guessing game of how long 🤷‍♂️
TheBandit
  Monaco172, Green1.2
Last little update for now. Was loosing first gear sometimes when stopping due to the stiff shift rocking around. As its a 3.0 it had bolts that would get in the way of a large o-ring. Also if I tighten the Stiff Shift down is squeaks loudly like a clown car made of balloons. Solution was to 3D print some spacers:
TheBandit
  Monaco172, Green1.2
Been flying round the Somerset countryside for a few hundred miles having a great time, but now back to planning and/or worrying about maintenance. To start off with I am not sure what the aux tensioner bushing is doing here. May need to give TwoTechs a bell. Only done 1K mile so far but not sure if I am happy putting another 10K down with it looking like that. Oil looked alright but changed it for Millers + new filter to start off my own service history
First time experiencing Christmas Tree Mode™️, had a little afternoon panic - but it fired up fine the next day with no lights on the dash so we will just pretend it never happened. Car has hit 100K on the odometer now so by Facebook marketplace rules its halved in value, shame.
Interior trims came out and got The Pink Stuff, came out really well. Just need to do the top dash but will wait as I want to install an amp back there while it is off
Underside is coated in oil, so it's rUnNiNg MiNt. Cleaned it up a bit so I could see how perished the dampened pulleys are. Will have a good think about those while I am at full chat. Have a feeling the eventual engine refresh will sting so should probably start saving for it now
Forum said the fuel rail guard is either 10mm or 12mm nuts. Turns out this car has 10 AND 12mm, so that's fun. I wonder what else I will uncover in time
Passenger arch liner shattered when I put the bumper back on so bought a replacement while these are still in existence. along with an audio stalk blank because I love buying expensive plastic
Not too fussed on the Fatty Induction. Either I need to put the old airbox back in or get a smaller cone as the current one stops all access behind the light. Had to replace the headlight height adjustor, and then the height itself with less than a fist-space of room.
Also been umm'ing and arr'ing about running a catch can or bunging a breather on the crankcase vent. Made a proper pikey beer-can catch-can and ran it for a few hundred miles and it came out clean so breather route looks best. Car will be back in the garage for a few weeks so will look at getting the inlet manifold off, change spark plugs and gaskets etc
Car gets 33mpg everywhere which isn't awful. Not getting 40's on the motorway, think its around 35, like others have had. But it does have cams and remap... Maybe that's just copium and something isn't right, need to pick up an iCarsoft and start making some graphs
  • Like
Reactions: T12
TheBandit
  Monaco172, Green1.2
@FatRS I have to keep reminding myself it's a project car
Hopefully my desire to learn remains greater than the desire to burn
TheBandit
  Monaco172, Green1.2
Got my s**t together and tackled the tensioner. I messaged TwoTechs and Terry gave me a call, I could get the tensioner replaced under warranty otherwise he gave me some tips on how to tackle removing the bolt
The trick was to wedge a screwdriver between the tensioner and the mount to hold it in place. Terry advised against using a hose clamp, but I did anyway. Just enough to release the full tension so if you ever read this Terry... Sorry. I also cable tied the tensioner against the alternator to minimise the risk of it slipping away from the mount/screwdriver if it was to get knocked by accident. Could have jUsT sEnT iT but I wanted to do this once rather then end up with a big blue paper weight
Had to loosen the engine mount and jack the engine to get this c*nt out
Cleaned the intake/engine top. Bunged up things that need bunging. Breather filter on the back
Plug holes look clean and the spark plugs look new, so I'm jUsT gOnNa SeNd it and assume that's all fine as it runs fine
New intake gaskets, I have a lower one as well but oil seems to be coming out of other places so that can wait
Before:
After:
3 bottles of Redline MTL just arrived so those are going in tonight. The Bandit got fresh Titan Sintofluid Oct 23 but I have had issues with gear selection from stationary as well as gear selection 3rd-4th. Might be the box/link/Yanoo kit but at least this will rule out fluid.
Thinking of going to the Newbury meet Podium Place 26th of may, will need to figure what I want to have done for then. Rear brakes need doing and the paint work needs a lot of attention that my initial images thankfully hid the worst of
Louis
I Love Ed Sheeran
View attachment 1688665View attachment 1688666
Before:
After:View attachment 1688669
Did they explain why they'd done such a s**t job in the first place?
TheBandit
  Monaco172, Green1.2
The rest of the work is sound and the offer to sort on warranty there or at my local renault garage was there - will chalk it down to "it is what it is"
The answer to your question is no, but I am trying trying to avoid any sh*t flinging
Louis
I Love Ed Sheeran
Just hearing some bad things about TwoTechs recently.
Klumpy Dumpy
The gift that keeps on giving. Shaftec's fitted a few years ago. How is the Borg and Beck holding up @Crayola ?
Borg and Beck has been sound as a pound
Part of me feels I should buy more of their parts because I've never once had an issue with the quality of their stuff with the limited bits I've bought
TheBandit
  Monaco172, Green1.2
Is that boot held on with a cable tie. 😂
PANIK
They're cable tied from factory lol
Phew...
If it's standard it will probably need replacing sooner or later
Sound as, never heard any complaints either worth a punt
Brigsy
  T.Turbo
Borg and beck used to be a decent brand back in the day, used their parts without issue. Kind of dropped off the radar but have been seeing bits from them again recently
TheBandit
  Monaco172, Green1.2
Went to remove cat, and the silencer rotates with it...
fun fun fun fun
TheBandit
  Monaco172, Green1.2
In no particular order after finding the exhaust cracked:
  1. Heatshield mount torn
  2. Heatshield mount epoxied (I think)
  3. Gearstick lift reverse plastic snapped
At least it has brass bushes in the shifter... And apparently an entire tub of copper grease smeared up in there
I have the old gearstick from my 1.2 when I added a Yanoo/Scenic shifter so shouldn't be too much work to fix
That's if I had snap ring pliers and the right grease so it will have to wait till tomorrow. About ready to fire it up and drive it into the nearest wall 🙃
TheBandit
  Monaco172, Green1.2
Got the rear in the air to change pads / paint calipers / see if there are any dirty secrets
What in the actual f**k is this repair. Exhaust mount, hose clipped, to a riveted bumper mount... At least I hope that's an attempted repair.
I have a contact for a welder to fix the silencer, but at this rate I might just look to get a new exhaust. This exhaust has custom mounts throughout which in my mind just means trouble in the long run... Evidently... Exhaust shop might have some idea of a fix, will have to see
More pics if you are curious of set up
TheBandit
  Monaco172, Green1.2
- Catch can fitted, can't hurt
- Airbox back in, PITA gonna look at cones again
- Painted rear calipers + new rear pads
- Redline gearbox oil feels great
- Now I have fixed the gearstick, it falls off the lift reverse....
- Centre silencer welded back up by Simon The Welder in Dilton Marsh. Great guy, highly recommend
Put together a new exhaust mount. Can't be worse than the last one
The bumper is truly warped to f**k, cracked and broken around the splash guard holes (and melted on the inside). I picked up a 182 bumper to trial fit
s**t... Turns out the original bumper was a cut. I had already trimmed some parts so can't sell it on. So...
Went for a centre cut as this bumper is now a spare (or is it 👀), might even go wider on the cut. Nothing on the car is standard so no love lost. I can always buy a 172 bumper and cut the slots out again
I did query if the tailpipe could be moved, but it would be cheaper to go down the 172 recut route
I forgot to take pictures but I made a heat shield above the exhaust inside the bumper as the foam and trim had melted on the original
Ant1
Brembo! Brembo! Brembo!
Wait for a 172 Monaco blue bumper to come up for sale, sack that exhaust off and fit a single exit as original.
Will look much better and prevent all this shite from reoccurring.
Bmac
How did you mount the fatty intake? Is it connected to the battery cover.
I have an intake setup that is similar but it is not secured to anything, so the intake pipe moves around and the foam. Filter rubs against the battery and light wearing it away.
TheBandit
  Monaco172, Green1.2
I put a cable tie around it to hold it to the metal support bar above. And some rubber edge trim to stop it rubbing on the body. The cone still rubbed on the battery and fuse box.
I'm thinking of going with the thinner ProRam filter to minimise rub. This style:
