Nimbus 197
Clart
New ecu didn’t work. I’m at a loss, checked all the fuses everything seems ok 🤷‍♂️
Matt Cup
  Iceberg 172 Cup
Just take it to Micks and get him to sort it? Will save you a lot of headaches surely?
Clart
I already took it there and he told me to buy a new column which I did. It didn’t fix it so was told that it could be the ecu that needed recoding. So I did that and that didn’t fix it either.
I’m gonna take it back to micks and just leave it with him to sort before I give up with it
Matt Cup
  Iceberg 172 Cup
I presume you have had all the relays and fuses out and cleaned the connections to see if they are at all faulty?
Clart
I’ve checked some but not all of them. I’m just hoping that there’s a really simple fix like a fuse, but I’m surprised mick didn’t suggest that if it was
RSRowe
  Megane 250 Cup
The steering fuse is inside the little black distribution box on my kit. It’s one of the 60a ones.
Doubt it’s that though. 😬
Clart
Car is back at micks. All troubleshooting with Renault technical etc points to it needing a brand new steering column and ecu. Will cost about £1k 😭
Not sure it’s worth me fixing it or punting it on as it is and taking a bigger hit.
Either way I think ive had enough so will probably be up for sale.
Matt Cup
  Iceberg 172 Cup
No idea but same fault apparently which seems strange.
Mick seems to think there’s something else going on with the wiring
Yeah that makes sense, might be something as stupid as a broken wire. Finding it will be the headache.
JamesBryan
Would have expected a second hand column and ecu to have at least done something.
The chances of them both being faulty must be slim.
I'm sure Mick will sort it, he knows what he's doing with that type of stuff.
Clart
Update from Mick - he thinks there is a short in the dash loom somewhere. Sounds like a right ball ache isolating and inspecting the loom sections.
RustyMojo
Bon Jovi Officianado
Sounds like it could be a decent bill coming!
Clart
It’s not looking good for this unfortunately.
Been at diamond for 6 weeks and still no further forward. Mick has ordered another column in the hope that it’ll work but I’ll be very surprised if it’s third time lucky.
if someone wants to make me an offer for breaking or an attempt to fix then feel free
Engine £1000
Box £1000
Coilovers/top mounts £500
Cage £450
Wheels £450
Seats, harnesses and brackets £800
Cup spoiler £200
V6 airbox £150
Scorpion exhaust & decat manifold £350
Brakes £500
Reckon you’d make £6k easy if you broke it but I havent got time or space
Matt Cup
  Iceberg 172 Cup
Well yeah duh.
But what did he wave his magic wand across?
Might be useful for anyone else who has the issue.
Clart
He thought there was a short in the dash loom, couldn't find it.
Ordered a used column which fixed it. He seems to think that the column i tried was either damaged or not function correctly when i fitted it.
So yeah, new column, The donor ECU off the steering column also worked, just needed coding to my VIN. so looks like that might have been a pointless exercise replacing that with a reflashed version
