Nimbus 197
Clart
New column didn’t fix it after all that, really hope it’s the ecu or I might set fire to it
Clart
New ecu didn’t work. I’m at a loss, checked all the fuses everything seems ok 🤷‍♂️
Matt Cup
  Leon Cupra
Just take it to Micks and get him to sort it? Will save you a lot of headaches surely?
Clart
I already took it there and he told me to buy a new column which I did. It didn’t fix it so was told that it could be the ecu that needed recoding. So I did that and that didn’t fix it either.
I’m gonna take it back to micks and just leave it with him to sort before I give up with it
Matt Cup
  Leon Cupra
I presume you have had all the relays and fuses out and cleaned the connections to see if they are at all faulty?
Clart
I’ve checked some but not all of them. I’m just hoping that there’s a really simple fix like a fuse, but I’m surprised mick didn’t suggest that if it was
RSRowe
  Megane 250 Cup
The steering fuse is inside the little black distribution box on my kit. It’s one of the 60a ones.
Doubt it’s that though. 😬
Clart
Car is back at micks. All troubleshooting with Renault technical etc points to it needing a brand new steering column and ecu. Will cost about £1k 😭
Not sure it’s worth me fixing it or punting it on as it is and taking a bigger hit.
Either way I think ive had enough so will probably be up for sale.
Matt Cup
  Leon Cupra
No idea but same fault apparently which seems strange.
Mick seems to think there’s something else going on with the wiring
Yeah that makes sense, might be something as stupid as a broken wire. Finding it will be the headache.
JamesBryan
Would have expected a second hand column and ecu to have at least done something.
The chances of them both being faulty must be slim.
I'm sure Mick will sort it, he knows what he's doing with that type of stuff.
Clart
Update from Mick - he thinks there is a short in the dash loom somewhere. Sounds like a right ball ache isolating and inspecting the loom sections.
Clart
It’s not looking good for this unfortunately.
Been at diamond for 6 weeks and still no further forward. Mick has ordered another column in the hope that it’ll work but I’ll be very surprised if it’s third time lucky.
if someone wants to make me an offer for breaking or an attempt to fix then feel free
Engine £1000
Box £1000
Coilovers/top mounts £500
Cage £450
Wheels £450
Seats, harnesses and brackets £800
Cup spoiler £200
V6 airbox £150
Scorpion exhaust & decat manifold £350
Brakes £500
Reckon you’d make £6k easy if you broke it but I havent got time or space
