3,304 days ago since I owned a Renault ..
Today I decided to swap out the checkstrap on the drivers side door.
Nothing went to plan.
1) The checkstrap didnt fit
2) I broke the plastic part that helps align the doorcard to the top of the door. Its superglued for the short term
However, I did have a supervisor.
Door card off
Back on - can just about make out the damage
Supervisor not impressed
What was up with your check strap?
My drivers door is incredibly creaky and white grease on the hinges didn’t solve it. So was thinking it may be that.
Its the part that is at the top of where the doorcar meets the actual panel. Provides a weather seal/strip against the inner window. I think it might be 7701207589?
Todays weather has been sunny.
I have a replacement weather strip
I have two check straps.
The replacement one looked too long, but looks can be deceptive. It fitted well and I didnt have a wrestle with the doorcar putting it back together. The door is now proper stiff to open and close in a good way. Am I supposed to apply grease anywhere?
I had noted the dash binnacle was rattling at any speed so whipped off the steering column surround and nipped that up.
I neshed the other side as I wanted to quit while winning. One for another day.
This car is the gift that keeps giving.
Yesterday I fixed the drivers side check strap and a few rattles.
For my service to the restoration of the car the boot lock is now clicking and won’t open.
Investigation required I think!
in an act of the car wont defeat me I decided today was the time to change the center exhaust hanger.
I appreciate it’s likely to fail again , but for now it will do.
Oh, and now the lock has completely packed in on the boot
Don't know how I haven't seen this soon.
Great thread and alot of this is like deja vu with my Cup.
Going through my check list
Completed:
+ Drive shaft clicking
+ Exhaust mounts changed
+ Check straps changed
+ Working center clock
+ OEM radio
+ Window washer pump changed
+ Lacquer painted on nearside front A pillar
+ Cup 172 decals purchased and fitted
+ Center high level brake light replaced
+ Polished front headlights
To do:
- Paint rear bumper / repair
- Fix cracked front bumper and paint
- Acquire new to me bonnet
- MOT in May
- Fix failed boot lock
This morning I broke the sound barrier getting over to a localist paint shop.
New paint acquired, sprayed and lacquer erm , lacquered.
Awaiting it to go off and will flat it with 3000grit paper and polish
Looks a mile better
Before
During
After
I tried to get the front bumper off but the nut was spinning the bolt and stuck. Got fed up so painted the brace between airbox and ECU.
Then played with my new parrot remote control so I can actually hear it.
Rock and roll!
After pestering @DiamondPerformance for an age on whatsapp I got down to 3000grit wet and dry , a lot of warm soapy water then some cutting compound which I applied by hand.
For an amateur effort its a solid 8 out of 10 and I dont think you would notice the repair unless I pointed it out. Sure the lacquer isnt super glossy but it doesnt catch the eye either!
Happy overall.
The third brake light didnt work and looking at previous MOT hadnt for some time
I removed the cup spoiler via the 6 torx screws and then measured with the multimeter across the now disconnected connector - 12V.
Must be the light then. Fortunately I had pre-empted this and bought a new LCD strip. I ever so carefully removed the top light and went about changing over the LCD strip. Fairly straightfoward TBH but I took extreme car not to crack the plastic light. These are NLA and I have seen upwards of £100 for them on ebay. Sod that!
Before
During
Some corrosion here but cleaned it up and it made absolutely zero difference
After. It didnt actually take me that long but I went out and forgot to get a pic!
Where did you order the LED strip from? Need to do the same to mine.
View attachment 1737501View attachment 1737502View attachment 1737503
Where did you get the door check straps from?
I replaced the drivers side one a couple of years ago and that clunks really bad.
I changed the passenger side one a few weeks ago and now that clunks, even after smothering it in lithium grease.
They were both from ebay and none genuine parts.
EBay!
Maybe the 5dr Clio uses the same check straps front to back.
I guess that's probably the reason?
The part number for the front is different to the rear.
Front is 7700842857
Rear is 7700842859
If they work, they work and hopefully won't start clunking again after a few weeks 🤞
I've ordered them.
Good effort.
You know the drivers weather strip seal at the top of the door you broke. I've done the same and found a replacement.
How does it come off? 😅
Good effort.
Door card needs to come off.
Pull the plastic quadrant off.
Pull the vertical plastic door pillar piece
Unscrew the door handle. Leave everything attached
Unscrew the electric window switch. Unclip the electric plug
Remove the speaker cover
Remove the 2 torx there
4 torx at the bottom of the door card
Get a separator trim tool and work your way around.
Lift the door card vertically.
Change over the bit your broke.
Refit …
The offside front pads have been sticking. I noticed it , the MOT station noticed it too.
I have today had the wheel in the air, and removed the caliper, cleaned the piston up and noted the pads were seriously uneven in their wear. The outboard pad was wedged in and took some gentle persuasion to come out. The inboard fitted well.
I have filed a small amount off each “ear” on the sticking pad , and swapped it to inboard.
I have been out for a quick spin and it’s better, not perfect. I suspect I’ll have to check all 4 calipers to ensure they are clear of crud.
Nothing else exciting to report
