andybond
Already on their way 👍lol that happened to me, there one moment and gone the next. Ordered a genuine pair from Lithuania 👍.
The one I had was missing these bits :What was up with your check strap?
My drivers door is incredibly creaky and white grease on the hinges didn’t solve it. So was thinking it may be that.
Seems an odd bit to be missing? Was it just flopping about in the hole then?
I have two new check straps to fit and a replacement piece for the top of the door card that I cracked .
I am on the lookout for a new bonnet as my is rough. The car isn’t perfect, but this lets it down.
View attachment 1736435View attachment 1736436View attachment 1736437
Did you learn new swear words especially for your cup as well?Don't know how I haven't seen this soon.
Great thread and alot of this is like deja vu with my Cup.
The third brake light didnt work and looking at previous MOT hadnt for some time
I removed the cup spoiler via the 6 torx screws and then measured with the multimeter across the now disconnected connector - 12V.
Must be the light then. Fortunately I had pre-empted this and bought a new LCD strip. I ever so carefully removed the top light and went about changing over the LCD strip. Fairly straightfoward TBH but I took extreme car not to crack the plastic light. These are NLA and I have seen upwards of £100 for them on ebay. Sod that!
Before
During
Some corrosion here but cleaned it up and it made absolutely zero difference
After. It didnt actually take me that long but I went out and forgot to get a pic!
You can just use any LED strip. Most of the time just cleaning the board solves it.Where did you order the LED strip from? Need to do the same to mine.
I got mine from here ; https://www.facebook.com/share/1C8dpXEjmc/?mibextid=wwXIfrWhere did you order the LED strip from? Need to do the same to mine.
Where did you get the door check straps from?Todays weather has been sunny.
I have a replacement weather strip
I have two check straps.
The replacement one looked too long, but looks can be deceptive. It fitted well and I didnt have a wrestle with the doorcar putting it back together. The door is now proper stiff to open and close in a good way. Am I supposed to apply grease anywhere?
I had noted the dash binnacle was rattling at any speed so whipped off the steering column surround and nipped that up.
I neshed the other side as I wanted to quit while winning. One for another day.
View attachment 1737501View attachment 1737502View attachment 1737503
EBay!Where did you get the door check straps from?
I replaced the drivers side one a couple of years ago and that clunks really bad.
I changed the passenger side one a few weeks ago and now that clunks, even after smothering it in lithium grease.
They were both from ebay and none genuine parts.
Cheers 👍 I'll order them.EBay!
2 X Rear Door Hinge Stop Check Strap Limitery RENAULT Clio Symbol I II | eBay UK
2 X Rear Door Hinge Stop Check Strap Limitery Right and Left Side. Clio Mk1 / 1990-1998. Symbol I II / 2000-2020. Both Side Right and Left. Our Part Number : KTM 1758X2 or KTM 1772 X 2. Original Part Ref.www.ebay.co.uk
Strange why it says " rear" check straps 🤔
I guess that's probably the reason?Maybe the 5dr Clio uses the same check straps front to back.
As long as they fit. That'll do for me 👍I thought the same but the ebay part thing said they fitted and I have fitted them too.
Used some lithium grease and there is no clunking. Yet
