My rusty Williams, where to start?
DBS
  Clio Williams 2
So, my Williams has a fair few rust problems. No surprises there I suppose...
I'm not quite sure how best to deal with all of it.
From what I've picked up on the forum, I was thinking of this for the chassis rails:
  • Wire brush
  • Surfex-HD
  • Deox-gel
  • Stone chip paint
Would you do the trailing arms and rear beam too? They're not looking awful, but, not great.
The front arches though... Once I start getting rid of the rust here, I suspect there’s going to be a massive hole. What’s the best way to start tackling it?
In a lot of places the sills have started to separate. Apologies the photo is a bit out of focus. Is it possible to try and treat it with some Bilt Hamber bits or am I better off digging it out and finding a welder?
Dicky Belly
  Whichever has fuel
Get yourself a pack of wire brushes, a couple of large and small drill attachments with wire brushes, and ideally a needle gun too.
Take as much stuff off the bottom of the car as possible. Rear beam and fuel tank definitely need to be removed.
Attack the lot, then see what you’re left with and go from there.
  • Like
Reactions: DBS
MAXRUNDOWN
There's a lot more work than a wire brush and some snake oil rust products required there unfortunately. If you're not up to speed with welding/body repairs I'd start getting quotes from some body shops that specialise in restoration work. There's nothing stopping you stripping the paint/underseal off with a knotted wire wheel on a grinder to see the extent of the rot first.
The rear beam is a straightforward remove, strip down and get it blasted and powder coated job.
ex-Chinese Dave
Remove as much rust and old paint/sealer as possible with wire brushes and drill attachments. You need to find the border areas between rust and good metal before you can make a full assessment and get costs. Some areas may not be so bad but expect to find some problems that you haven't seen yet.
DBS
  Clio Williams 2
Thanks, sounds like it's definitely beyond me.
Its booked in to have the timing belt and gearbox leaks sorted in October. After that I'll start getting the rot out and book it in at a bodyshop.
I've seen good reviews on the forum for a place in Braintree who do classic cars. Its only an hour away from me so I'll try them first.
DBS
  Clio Williams 2
Thanks, I hadn't thought of that. Sounds stupid to say, but I hadn't planned on spending much money on the bodywork. Now its pretty obvious I was waaaayyy too optimistic :ROFLMAO:
Dicky Belly
  Whichever has fuel
It’s not ‘that’ bad mate. I just had 2 x rear outer arches, one inner arch replaced, one sill replaced, one sill repaired, all painted and looking completely original on my 1989 Orion and it cost me £200 in parts, £800 cash to the welder, £1500 cash to the Bodyshop. And I couldn’t be happier with the result.
DBS
  Clio Williams 2
That's a cracking video. I might look up their welder.
Is it normal to find a welder and bodyshop separately? Or do most restoration places do the lot?
MAXRUNDOWN
You need to be quite picky when it comes to finding someone to do the welding.. Most crash repair/volume work body shops won't be used to rust repair/restoration work, and you definitely don't want it done by someone that does 'MOT welding'
The last thing you want is to pay good money to end up with pigeon s**t patches under filler and some shiny paint and underseal
DBS
  Clio Williams 2
Good shout, thanks. I'll look for a welder with decent recommendations, or at least one who specialises in restoration work.
16V F7R
  Clio 16V
Defo examine the condition of the shell before spending any money on anything else. If you have a budget/limit of what you will spend on the car then you may exceed this on bodywork and paint alone depending on how far you want to go with it. Good luck.
  • Like
Reactions: DBS
DBS
  Clio Williams 2
Ah that's a shame. I've found two places in Suffolk who do classic car restorations so I'll get some quotes from them next week.
DBS
  Clio Williams 2
Thanks, I'll keep them in mind.
The first estimate came back today:
To cut out, laser remove rust, replace with repair panels, weld, dress and prime:
  • Torque boxes x2
  • Inner and outer sills x2
  • Inner front kick plates x2
  • Rear legs both sides
  • Rear jacking points and suspension mounts
  • Spare wheel cradle
  • Front arches x2
  • Boot floor panel
  • Drivers door pillar
  • Drivers door surround
Came to just £11.5k without paint, and assuming they can find all the panels....
terryc101
  • Torque boxes x2
  • Front arches x2
  • Boot floor panel
Jesus, I might as well scrap mine now 😂
  • Haha
Reactions: DBS
MAXRUNDOWN
  • Torque boxes x2
  • Front arches x2
  • Boot floor panel
Jesus... That seems steep, is it that rotten? Who was that quote from?
Dicky Belly
  Whichever has fuel
That’s an absolutely ridiculous quote.
My boss paid £12k to have the entire underneath and everything on top apart from the roof painted on a 4 door Sierra. That included 2 new sills and arch repair panels.
That very much seems like a price of “we don’t want this job but if he pays this stupid amount well do it” to me.
Why don’t you rent a 3.5T car transporter for a Saturday and take it to a few places. It’s only about £150 for the day plus your fuel. Could save you £££ in the long run.
npt
  BMW 320d- 172 cup
You'd be better getting a good shell and using that instead of repairing the one you have if it requires what you've listed above, most quotes will be high as its a lot of work, once you add paint the shell will cost you more than the cars worth when built, thats the route I'd go down anyway
DBS
  Clio Williams 2
The rust isn't terrible in my opinion, the quote is certainly far more than I thought it would be. It's from Suffolk Classic Services.
I just heard back from another garage who quoted about £10k to replace the sills and arches. They said they'd have to fabricate the sills but arch panels were available. That includes Cobra underseal and paint, but still seems very expensive
That's a great shout, I think I'll shop round a bit more. That welder from the Auto Alex Williams video isn't that far from me so I'll try him too.
I'll also take a look for decent shells, just in case one comes up.
cat171
I messaged @frayz last year as he'd had some stuff done on his inferno 182. I was looking for good place to do some paint on my 172 (I still haven't had time to take it to them)
He used VJB Classics in Maldon, Essex (I hope he doesn't mind me saying this)
We are both in Essex.
npt
  BMW 320d- 172 cup
Worst thing is once you get into it there's usually a load more fabrication needed, not always but its usually the case
Matt Cup
  Leon Cupra, 172 Cup
If this can be saved (well body swapped with a s**t load of fabrication) then anything can.
MAXRUNDOWN
https://www.youtube.com/@Joshwaa___ this lad seems to do fairly decent welding/rust repairs..
10k to do all of the welding and a full paint isn't unreasonable, assuming it's done to a high standard. If you're looking to spend a lot less then finding someone a bit more pragmatic who will make the shell solid so you can get a presentable blow over done is entirely possible.. I was quoted £2k for a blow over on my cup from the body shop that painted my back bumper, that would have been bumpers/skirts off, lights out but glass in and doors/boot done on the car, no door shuts or under bonnet. I'd expect to pay about a grand a side for inner and outer sills to be done on top of that, so if it does need a few other bits done you could be all in for circa £5k if you're after something presentable but not show quality.
16V F7R
  Clio 16V
Getting your cambelt done is the least of your worries.
It is mental what some body shops will quote nowadays and I know everything has gone up. A lot don’t want the work and it is always more work than you think it will be so they like to give themselves a comfortable buffer and either make it well worth there while or they’d rather not do it. Hopefully you can find a decent bloke or company that wants to do it and will do a decent job for a reasonable price.
Keep looking and good luck. Nice to see another one hopefully being saved but not an easy decision when you start getting these figures thrown at you.
DBS
  Clio Williams 2
Yes, the repair costs are definitely testing how much I love the car :ROFLMAO:
Just got another quote to fabricate and install: Outer sills, lower + upper inner front arch sections, prime, underseal and paint those areas for £9600. I'm not sure it's wise to do the outer sills and not the inner sills.
I can't find any of those bodywork sections anywhere so they probably will have to be fabricated. Apart from maybe these:
But I'm pretty sure it says they fit the Williams 1, when I set the filter to Williams 2 + 3 it doesn't say they fit. Does anyone know if they're compatible?
I'm off to VJB in Maldon tomorrow for a quote, I'll see what they reckon
Matt Cup
  Leon Cupra, 172 Cup
Here’s the differences between the 3 versions.
Pretty sure it’s only paint and spec that makes them different. Oh and AC.
