Updates
Basically done nothing to this since Anglesey apart from clean and drive, it all works so there was no real need to do much.
Renewed insurance for the year with Greenlight. Still cleans up decent and using the di vessel for rinse really makes the yellow pop.
With a Spa Francorchamps trackday coming up in the next few weeks i made an effort to get it jacked up and checked over yesterday.
Small list to do.
1. Steering rack bush on passenger side. To be fair this had developed a little bit of play before Anglesey, but time was not on my side to change it. Its pretty minor but will do it.
2. Both rear wheel bearings have developed minor play. This pains me as the discs and bearings were changed for quality snr before Anglesey and torqued to the correct spec of 220nm. It could be due to the semi slicks and extra load on the bearings, but this will be the 3rd passenger side and 2nd drivers side rear bearing swap its had in my ownership. Ive fitted tons of bearings with success so its not a technique issue, and stub axles look/measure fine.
I went a bit tighter on rear hub nut torque yesterday which took the play up to a degree but looks like ill be changing them.
Discussed this with people i trust and its apparant that the quality control on snr has slipped/bad batches. As bad as the usual chinese crap.
Apart from the above, everything else seems good. Half days work at worst for the minor jobs.
Whilst on the jack, i changed the oil for fresh valvoline synthpower 5/40 and purflux filter.
Engine bay wiped over.
Will get the above sorted in next couple of weeks.
Thanks for reading!!
