yes but you do have to grind a bit off the middle too but thatsthe easy bit. getting the stubs out is less soOK thanks, and did you just drill and tap the rear beam for the 182 stub axles?
i never did no. only ever looked at how to modify the original. as with anything i guess there is always a way but i dont know the mounting hole spacings on this one.. look wider.. or the shock spacing.. i suspect that would be your main problem but maybe also change in wheelbase alsoI'm looking fitting the megane scenic rear beam (99-03) but need to check they fit. Did you ever look at that option?
Did you change the torsion bar on it?i never did no. only ever looked at how to modify the original. as with anything i guess there is always a way but i dont know the mounting hole spacings on this one.. look wider.. or the shock spacing.. i suspect that would be your main problem but maybe also change in wheelbase also
the standard bar is retained but following what renault did on these beams for gr.A i added the option to add an extra external arb. the one fitted in the photos is a front mx5 standard one but i actually changed the front arb setup to take mx5 ones too so there are lots of options on diameter etc for those and you can interchange both front and rear from the same setup so saving 1/2 the cost of options effectively.. just change the bar and bushes.. ive got something like 25 or 26mm front and 19mm rear currently..Did you change the torsion bar on it?
took me kin ages to find suitable bars.. looked at porsche 924/928etc but mx5 actually work wellLooks great @ClioMaxi
Im going to try a similar setup for the rear arb on my extra van, basically same axle apart from drums/24mm torsion bars.
build has been going on so long i started documenting it on a chalk board.. but loads of photos i can dig out.. shell is an ex cup car.. sadly now full of holes so thats the next bit to sort but 2nd engine partly built. low ratio lsd jc5 built and most other parts built more or less from scratch.. if i remember ill dig out some more stuff and post it..
i think i used standard mx5 centre brackets and bushes on the back with a 6mm plate or something welded to the beam and tapped to take bolts.. for the droplinks its a pair of male and female rod ends to suit the standard shock bolts. the front bushes were custom machined alloy to take mx5 polybushes and fixed to custom welded plates on the subframeHi Mate, what did you use for this bracket and the bush? And what size turnbuckles for the ends?
sorry i dont but if you take the rim width in mm, divide it by 2 then add the rim offset, multiply by 2 and add the published track width you will be close, not allowing for camberHi Mate, you don't by chance happen to know the track width from outer edge to outer edge of tyre at the front do you?
something sounds a bit off. the total width according to the attached doc is 1741.. ah minus the offset for a start so 1696 sounds more likeDoes 1590mm sound correct for the published track width? Can find different numbers
If so my rims are 7J 178mm / 2 = 89mm + ET36 = 125mm x 2 = 250mm + 1590mm (Maxi Track width?) = 1840m
thats the old prima maci kit iused to have. it is narrower. i have pictures of it on 8 inch et 11 rims with a comparison against the full maxi wingView attachment 1764772
my et11s will be up for sale next year.. ;-)
