Mr Trailer Man
Don't forget to remove the hub insert from the track rod end before you bin them 😅
First thing I thought when I saw the picDon't forget
First thing I thought when I saw the pic![]()
Yes Krarl, those ones. 🙄Are those the wheel bearings you wanted me to press in?😬🤣
Don't get ahead of me 🤣.Don't forget to remove the hub insert from the track rod end before you bin them 😅
I only thought it would need help with the emissions, all that s**t is easily fixed.He's done you in as he thought you were vosa 😂😂😂😂😂
I don't think you found your friendly mot garage mate
Yep I tried the big f**k off milwokky but I did spin and I didn't jack it. My stress levels were high last week so resorting to destruction came quicker than usual. I did think about just throwing a match in the garage and shutting the door too 😂.
Well I can't see the other side going any easier so I'll remember that 👍.Try the jack trick next time, enough load on it that it's almost picking the car up and it usually does the job.
Silver lining and all that 😂.At least you got your knob wet.
I told him they didn't fit the way he suggested and that they aren't against any moving parts so won't rub as he said.Tell the tester to stop being a dickhead and use his brain.
You have them routed correctly.
This is factory location.
