JamesBryan
Don't forget to remove the hub insert from the track rod end before you bin them
First thing I thought when I saw the picDon't forget
First thing I thought when I saw the pic![]()
Yes Krarl, those ones.Are those the wheel bearings you wanted me to press in?![]()
Don't get ahead of meDon't forget to remove the hub insert from the track rod end before you bin them
I only thought it would need help with the emissions, all that s**t is easily fixed.He's done you in as he thought you were vosa
I don't think you found your friendly mot garage mate
Yep I tried the big f**k off milwokky but I did spin and I didn't jack it. My stress levels were high last week so resorting to destruction came quicker than usual. I did think about just throwing a match in the garage and shutting the door too.
Well I can't see the other side going any easier so I'll remember thatTry the jack trick next time, enough load on it that it's almost picking the car up and it usually does the job.
Well I can't see the other side going any easier so I'll remember that.
Silver lining and all thatAt least you got your knob wet.
I told him they didn't fit the way he suggested and that they aren't against any moving parts so won't rub as he said.Tell the tester to stop being a dickhead and use his brain.
You have them routed correctly.
This is factory location.
In the quiet hum of ATEC Align,
