My cheap(ish) 172 Cup
Polynesian
  Alpina B3, 172, 325i
Sharpie did not work well on mine. In the end I junked the whole setup when input buckets in and used BMW receivers… sorry.
Polynesian
I’d also tried Gtechniq trim restorer, slight improvement but still like one of those old white dog poos.
ex-Chinese Dave
Yeah, I think some of these videos online are probably not of the first attempts. I gently heated mine but the point at which it starts to look crap happens so quickly that all you're left with is something that needs replacing.
ex-Chinese Dave
First time in weeks that the drive was free and perfect temperatures for working outside…
I decided to fit the door trim that got to replace the exploding one. I took the card and bits off again and had to cut the strip a little to fit. It’s not the same as the original but you wouldn’t know unless you looked at the other door. I couldn’t find another so it’s fine for now. Some of the trim is loose but I guess that’s a lot of 172’s are the same as there is nothing missing or broken. I need a fix for it and have asked in the interior thread.
I also flushed out the screen wash as it was not a strong dilution. I’ve checked that no pressures were down in the tyres but it was -5 when I checked so I just brought the near side front up to the others. I’ve no idea what the pressure should be at such low temperatures.
I e a chance again this week to do a few other bits….
  • IMG_5930.mov
    78.6 MB
Louis
I Love Ed Sheeran
Show a photo of the inside of that bracket and the inside of the door where it fits.
I'm sure it's meant to have a little hook at the bottom but I can't remember now
ex-Chinese Dave
This was inside the door card loose when I took it off. I’m not sure how it fits. If this is what you mean I’ll have to take a look at the other side as well as that’s not perfect but not as loose as the drivers side.
ex-Chinese Dave
Yesterday I decided to tackle the issue of the top half of my heated rear window not working. I had already checked the contacts on each side and they looked perfect. So, I bought a cheap tester and a conductive paint repair kit from eBay a few weeks ago and in I went!
I looked at a few guides on YT and they were easy to follow. I used the tester as described and found four tiny scratches in the wire on each line. I cleaned it all up and opened the paint only to find it had gone hard. Bummer! So I ordered some from Halfords and collected it today. I've put in on as per the instructions and will test it tonight. If it all works i'll need a new blade to tidy up the edges but i'll be happy I didn't go down the route of a new tailgate!
ex-Chinese Dave
Well, b****cks! None of the 'repaired' lines work. Tomorrow i'll go over them again with another coat of the paint and do another test just to make sure there aren't any other breaks i've missed.
Brigsy
  T.Turbo
The mrs 225 has same issue on rear heated window, i also tried the paint and no joy. Worth a shot though, 2nd coat wont hurt
ex-Chinese Dave
I tried another coat of the paint and there is no joy. I'll give it another one tomorrow but it's looking like a fail on this. At least the bottom half works.
ex-Chinese Dave
A lot of hassle, though. There is a tailgate going in Hull but i'd have to get it and fit it and there's no guarantee the heated window part is working.
ex-Chinese Dave
I still have the slight knocking sound that i'm convinced is coming from the gear selector rod under the car. I've got some small springs which I'm going to try and fit in such a way that it dampens any movement but still allows the gear change without hindrance. There really isn't much to fit the springs to so I'm going to have to come up with a good idea to do something that allows me to find out if it's definitely the rod that makes the noise. If it is it's something inside the gearbox that is loose or broken. I'll do this on Monday when I have the driveway free and hopefully I get a result.
Polynesian
A little bit of a sale on at the moment on badges -
Thanks for posting this. Unfortunately still not that far off of the price of my Alpina badges, and I just can’t bring myself to do it for Renault ones! I know I will eventually. Do each of the three rear badges need the little clips?
Polynesian
Do you think there was any damage to the selector rod? See anything at all? It just sounds weird… I guess you might know more on Monday. Hope you can see an obvious fix (and not a gearbox internals issue).
ex-Chinese Dave
I don't think so. The gearbox was rebuilt by Mark and fitted by Birchdown and I've 100% trust in them. It's got to be something stupid or something that has just broken. I doesn't affect how the car drives but it's annoying. Matt Cup has sat in and heard it so it's not just me.
ex-Chinese Dave
Boring update to follow...
So I've not made any progress on finding the cause of the clunking noise (not the one from the suspension). This noise really ruins the driving experience because everything else is perfect when driving. I'm sure if I have the geometry done correctly that will make it drive even better but it's a joy to drive. I was convinced a few days ago that it was clutch related, but driving home last night when cold I couldn't hear the noise so well until the car was warmed up. This is making me think that it is the gear selector because when the gearbox oil is cold it probably damps the movement a little but when warm whatever rattles is free to move. Makes sense? Also, the only thing loose under the car is the gear selector rod because it's supposed to move, obviously. Anyway, on Tuesday I have the driveway so i'll get on and under the front end and push, pull, knock and rattle every single f***ing part to make sure there's nothing i've missed. If I find a rogue 17mm spanner under there i'm going to throw a party !!
ex-Chinese Dave
Back under the car today...
There is no 17mm spanner lurking in a corner, sadly. I've done a few videos and sent them to Mark for some advice. I tried using a few springs to stop the gear linkage moving around in the hope that if I eliminated the noise I knew I was on the right track, but there was no way to do this without compromising the gearchange. So i've refitted the undertray and i'll wait for any advice. The linkage does seem a bit loose but there is no free play in the joints under the box. It does touch something under the heat shield but that's right under the gear knob which is not where the noise is coming from.
I noticed that my brake discs have those lines running from the outer edge to the inner edge so i'll be ordering new discs and pads along with a new thermostat for when the new rad is fitted.
ex-Chinese Dave
Just got some great feedback from Mark....
I have to pack the rubber boot under the gearbox with grease (there is nothing in it at the moment) and if it makes a difference then the selector pin may be goosed and needs changing. If not then the shifter arm may be goosed which is a big job to solve. That may mean having to turn the radio up.
ex-Chinese Dave
Had a go at packing the rubber boot with grease yesterday. Here's a link so I don't have to retype everything again..
I'm taking the car out again later (it needs a battery check at the local motor shop but I think it';s fine, just a check up) and i'll double check that the noise is less with the boot packed with grease. It's looking like I need to replace the shifter pin at best, and at worst it's a gearbox out job which won't be happening any time soon.
I'll ordering some new bits on Monday for the service in a few months (thermostat, front pads and discs) and then trying to do a full machine polish as I won't have easy access to a power supply when I move house in a few weeks time.
ex-Chinese Dave
I've also just seen a decent looking front bumper on eBay for £200 and put an offer in. If I get that it's easy to fit (I've had plenty of practice!) and a lot less hassle than putting the car into a body shop to spray up and repair a very tired bumper. Looks like it just needs a good polish.
ex-Chinese Dave
I’ve also ordered new front discs and pads, thermostat and gear linkage repair kit. I really should be turning my focus to getting my new pad, but it’s more fun buying car parts than pots and pans :ROFLMAO:
ex-Chinese Dave
The front bumper has arrived. It’s exactly as described, but it does need a few bits repairing on it. The idea is that if it was in good condition, and it is, then this would be a sensible option to have painted at a body shop rather than my damaged one. There is of course a chance that I can polish and repair this and the paint match is good enough with my car that it won’t need to go into the body shop. Don’t forget, the paintwork is 23 years old so although it looks okay it’s not perfect. I’ll get to work over the next few days cleaning, repairing and polishing the marks in it and see how it looks. Hopefully I can fit it on Wednesday and get a better picture. All the plastic inserts on it are much better than on mine and also the attachment points for the wings are really good considering its age. Even the fog lights surrounds and fogs are in good condition compared with mine and if they work, I will leave them in.
ex-Chinese Dave
I’ve just had a go at polishing out the worst marks on it. There are a couple of spots where the paint has been rubbed off and they would need repairing. I know from experience that if I do the touch up correctly the touchup paint will definitely be in contrast to the original paint. I think what I will do is clean this up as best I can, repair any imperfections and fit it to the car to see how it looks. I know that if a body shop was just going to spray the bumper on its own then it will be around £250 to do so.
ex-Chinese Dave
This morning I went over the bumper with 3000 grit wet and dry. There’s a ton of road rash on it and some scratches that have needed touchup. I’ve done the touchup and once it’s dry I’ll wet sand that down and then polish the whole bumper to see how it looks. The local body shop, who have a good reputation, have said that they can match it without it being fitted to the car. If I’m not happy with how it looks after polishing I’ll take it round to them and see what they can do. I’m just a bit concerned that a freshly painted front bumper, even with the correct colour match, might stand out a lot.
MAXRUNDOWN
I think I'd rather have a freshly painted bumper thats not a 100% match than one that's peppered with chips and scratches.
I had my back bumper painted, edge to edge with the tailgate and rear quarters you'd never know, the match is perfect, they charged me £280 all in.
ex-Chinese Dave
Yeah, to be honest, it’s looking like this will need to be repainted. At least if it is they will be painting a good bumper and not a damaged one.
As yours was painted whilst it was on the car, how long did they have it for?
