172 C.U.P. (Complete and Utter Poo)
This hasn’t been a great winter/spring for the Cup. And it’s MOT day tomorrow…
I finally got the gearbox mount refitted, and then realised that for an MOT, any seatbelts need to be secure and the airbag light off etc etc. never mind the rust. Whacked some 3.3 ohm resistors in the airbag connections and both the airbag and the SERV light went out. Great. Lost the bolts for the seatbelts over the last 9 months or so, not ideal. Managed to get the front passenger belt secure- I have bucket seats but standard belts. At the rear I was worried that flappy belts would be a fail- I undid them at the base to get the interior panels off to check for, and find, rust.
They’re now bolted in, the rear bench is out and a nice carpet in there. I’ll remove the rear belts fully when I have time.
Put the alternator shield into the new grille, took out all the s**t (new wings, suspension, driveshafts, etc etc) to make it at least a bit smart. Washed off all the pollen.
Please MOT gods, be kind tomorrow.
I forgot to mention the insane flooding. I think I have it finally dried out but it was a long process. Don’t want to ever do that again. It looked like it was down to my centre drain- not blocked but the insert was lifted up and I guess preventing water draining. Litres of it in the car…
Wheel bearings were changed about 200 miles ago at two techs, so I think that advisory might actually be for the clicking shagged driveshaft.
My front subframe is a mess, if I’m changing the suspension arms, dampers and bushes anyway, should I just go ahead and do it all with a new subframe?
Rear plate is absolutely fine, insane advisory to me.
That's a shame.. sounds like a good opportunity for a front end refresh though. Drop the subframe and get everything (subframe, arb, bottom arms hubs etc) blasted and powder coated
Yeah, seems to make sense as I would want to do it at some point anyway.
The headlamp aim is a pretty obvious one-I have a bulb dangling in the holder!
I'll need to talk to two techs about the wheel bearing as they literally just changed them both!
The rest is all fine for me, not real surprises. I wonder if the "service brake" could just be binding/ rusty brakes from it being stood for nearly a year. It's done about 600 miles with me in the year... maybe a hard run would sort that?
Just a thought- front wheel bearings were done, I then added spacers- wonder if a spacer is giving the effect of a loose wheel bearing???
I love when people on here say “10 minute job” and “just do it there’s nothing complicated”… it doesn’t work like that for me.
I’m working through the MOT fails and just have sticking caliper- hoping a hard drive might sort that??? And new front dampers.
All the guides say you don’t need spring compressors. Which is half true, but the damper piston retracts immediately that it’s not held tight, so by the time I have the top mount sat over the spring upper, the piston has retracted and I can’t get the little collar bolt on.
How do you all do it?
Sorry but this forum has completely corrupted me on this term of phrase. 🥴
I'd follow a guide on here that said it would take 30 mins start to finish and it would take me 3 hours. Just comes with experience I think.
I’m in no rush, except to do the retest. I have spring compressors coming tomorrow and hopefully can then be easily done. With a second pair of hands I could probably have finished it today. No big deal, just annoying!
MOT retest on Friday- headlight: sorted, indicator: sorted, brake caliper pins: sorted, wheel bearing: on the basis that they are brand new oem, I’m going to guess this was an effect from the spacer, so removing them for the retest, leaking dampers: have spring compressors and will have the new Cup dampers in and ready.
It better pass after all that.
As above check hub nut torque, spacers shouldnt make an issue unless wheel was nearly falling off. Wiggle test 12-6pm to check for play, if still has play will be bearing issues.
Same here. I’ve to put my new bumper on this weekend and although I had it on and off a few times I just know that this time the new one will take me hours to fit!
Sure enough… got the nearside damper and spring on, relatively straightforward. So what, another 10-15 mins to finish the job and be ready for Friday's MOT?
No. Look at the threaded top of the damper piston where it comes through the top mount. How the f**k am I going to get that out now? The sidewall of the piston top is split and so you can’t get any purchase on an Allen key in it- swan neck spanner just spins the entire damper. f**king f**k. So pissed off with this car. I need to get everything replaced so it’s reliable to work on. Not old s**t.
Any ideas on how to get the old damper out now?
Thanks everyone. I’ll get it done tomorrow and I appreciate the tips. At least I’ll have a badass tool for all kinds of jobs I can f**k up in future now!
Just grip the piston in the centre of the spring, Stilson or vice grips, put a bit of leather if you have any against the jaw to save marking the piston
Ok, I got everything sorted and dealt with all of the MOT fails, and the car went in today for another go. I had a call about 20 minutes later and they sent a video- it pissed its coolant all over the place! The tester stopped the test so it wouldn’t get another fail and we took a look in the engine bay- all new hoses and rad earlier this year. Couldn’t see any coolant leak anywhere…
I got it home (1 mile) and it hasn’t dumped the water we topped it up with? And is this likely to be something like the heater matrix? I really can’t see any leak or loose/moved clamp anywhere.
f**k me this car is slow to get a pass!
As above. I had to rebuild the top of an XR3i engine after the cambelt snapped. We didn't have any coolant before we tested it so we just filled it up with water. It pissed out when at warm and idling due to us not plugging the fan back in but left no trace as it was only water.
Different car, but had the same issue on my wife's rover mini. Fan had died and would piss coolant. Sorted fan out, no problems since.
Pressure test the cooing circuit for leaks. At a guess rwd fan not come on due to corrosion on relay pins.
No idea why some mot testers insist on leaving the engine running all the way through mot test.
Haven’t had time to even look at this until today. Started it up and I could immediately see a small drip coming from the new expansion tank. It’s a Febi one, has done about 5 miles… I’ve ordered another and booked an MOT.
I did take the opportunity to replace some relays with new ones, cleaning the sockets and spraying the pins with contact cleaner.
Still loads to do and hopefully that will include some welding and paint later in the summer. MOT first though!
The fastest I could get hold of an expansion tank was an eBay mahle one… made in China… it’s in and I’m running the car, no leaks. I’m waiting for the fan to kick in but it’s taking ages- is that normal?
I can’t recall ever hearing my fan come on 🤐
Guys, help me out with this. I obviously won’t be taking the car back to kwikfit for the mot- guy failed it on two things that weren’t fails 2 miles ago. FFS.
Tyres are easy. What am I going to need to do to sort the other new issue- shown below. He said tie rod ends. What does all of your experience with Clios say? Thank you.
Never heard of it being called a drag link before 😅🫣kwik fit jobsworth 😂looks like it’s Probly wants a inner tie rod joint or maby try a different test station
