172FF BACKBOX BRACKET PRICES ? ?
Me Again, i'm afraid !!!
Been looking to change back to my standard backbox :)
I was having a scan at backbox bracket (the one with exhaust rubber built into it and held onto car with two bolts).
The exh rubber in bracket is totally shagged :(
Anyone ideas how much one is from Renault ?
Or am i cheaper mail oredering one from K Tec or something ? ?
you can use cable ties as a cheap fix, to hold the rubber up. Or around £15 from renault.
They are a pain in the arse to remove though, best trying the cable ties first.
Ok cheers Dave, i'll try botching it with beasting cable ties first. ;)
Thin things will just break
i used metal cable ties at one point, held it pefectly.... im not sure if plastic ones will melt or not....
although check out JLO's efforts, im sure he wont mind me attaching this LMAO!!
Nice ! !
LOL
How many tie wraps has he got there ? ?
HA HA:)
Is this for real ? ?
Or a temporary repair ? ?
Wonder how long my tie wraps will last ? ?
he told me that lasted 6 months LMFAO
so i guess his was permanant instead of temporary.... cant wait for him to see this post you'l get the full explination lol
EASY EASY job to change them, and mine was £21 from dealer. Takes about 15mins to do, the exhaust sits much better and lost a tiny rattle I had before. Why bodge when you can do a proper fix for £21 and 15mins???
Agree with the above
You can also file out the slots on those brackets as well if you need more forward/back movement to clear exhaust hangars;)
motherfookerrrrrrrrrrrrrr.. lol..... pmsl
it was on for only 1 day... my back box was hangin down...
not 6 months..
grrr f0xy, im gona run u over... lol
I think i'll just do that, buy one seems the right way to do it ;)
File a slot where ?
In metal housing in bracket just enough to slide exhaust bracket into the rubber ?
File a slot where ?
The Renault bracket has slots in so you can move/adjust it forward & backwards....you'll see what I mean when you get one.
I fitted an aftermarket exhaust and it just touched the hangar so I used a round file to make the slots longer therefore offering more adjustment.
Been spot on ever since...not a single knock
File a slot where ?
Just had a squint at the one on car and theres two slots the bolts that hold it on run up and down..
I got ya now
Cheers Dude :)
