My valver/172 project
started to wrap my manifold to protect the steering rack/pipes and brake lines
didn't realise how much it would take, gonna use about 30' i reckon, just waiting on some metal cable ties now
Why dont you just wrap the pipes and cables in heat protection or install a heat sheild that would be easy?
From experience mani fold wraps always fall off no matter how neat you do it and unless it done properly doesn't really help.
Good luck to you thou!
did you wet the wrap matt?
i did my 106 manifold, if you spray it with water (dont soak it) before applying it makes it much easier to work with, also dries tighter. mine has never come loose, only problem is that ive caught it on the ground a few times and it has torn in places. not a problem with the clio's though.
i've not properly put it on yet, was waiting for the ties (which have arrived now)
cheers for the water suggestion!
fuel_slut, I'm gonna take my chances with it, i've seen a few done recently and they all still look ok and seem to hold the heat in
my GMC 4-1 manifold, wrapped by yours truly
and then sprayed with high temp paint, acts as a sealant aswell to stop water getting in and rusting the pipework
i'll stop pic whoring your thread now :rasp: ;)
engine out.. again :mad: - neighbours must think i do it for fun
heres some pics of the bores - the flash accentuates everything (e.g. the hone marks) but you can clearly see where a piston/ring has 'rusted' to the bore - or am i miles off?
building up a collection of crank cases :dapprove:
they see me rollin'
atleast the welding on the diff circlip is holding up! (even after track abuse)
I could go with that being the problem seeing as its not a complete loss of compression, wouldn't like to say whether thats salvageable though without a slight bore and oversize pistons which I don't think exist.
Im no expert, but that looks like your problem.
When you run your finger over the suspect cyclinder is it rough/pitted or un even?
if piston rings are really expensive (£500) - then that takes them out of the equation
Can i not just use piston rings from engine #1 with crankcase #1 and the crank/rods/pistons from #2?
would it *need* to be honed, as it was working perfectly (compression wise) when i took it apart!!
if not, i'll have to get a new block.... again!!
Rings are about £20 a cylinder fella! You have the engine out, dont just bodge bits of different engines ow or you'll be back to square one. Might aswell do it properly and whack some high comp pistons in and get the block honed. It wont be THAT expensive...
Thats FUBAR'd, rings are not the issue.
A hone will not fix that and depending on the depth of the corrosion, even a set of oversize pistons might not fix it.
maybe not at all - it seems piston rings are renault only, and very expensive :(
I'm taking them to an engineering place tomorrow as my final option, then its on to a new block!
not happy :dapprove:
I got some rings for mine from groetze or something. Steve at Birchdown aranged them for me! £18 per cylinder...
oh right, old block.
In that case, old pistons new rings and a rehone....but were only talking like 1-3 tenths of a thou max.
rings are available from plenty of places, Perfect circle, Federal Mogul, Gotze. A decent engine reconditioner/machinist should be able to sort you out
no where can source piston rings and i do not have the money to upgrade to forged etc..
so I'm using my original crank case and mains caps with the crank/bearings/rods/pistons from engine #2
I'm going to reuse the rings from #1 and put them back in the cylinder they came from nd hope it works basically.
stan@apd had my pistons and rings cause i sent them to him along with the rods and crank for the original grinding. this never happened cause the crank was bent so they've been sat in his workshop. they were picked up by a courier yesterday and were meant to be delievered to me today so i could maybe start building the engine up (I've got the crank in and a few others little things already).
However, they've not arrived. on my way to sainsburys earlier i passed a broken down DHL van with an AA mechanic scratching his head, knowing my luck my pistons are in the back. by the time i'd thought about being cheeky and pulling over to ask, i was long gone, so I guess i'll have to wait :(
the curse of LMG is spreading, no other vehicles can even transport her parts without sucomming to the curse :D
not sure when i'll be able to get it all running, and even i'll be impressed if the straight swap of the crank works too :(
bmh.01 sent me the torque settings for the engine too, which is very handy to have. turns out its pretty much the same as what haynes says for the 'f-series' engines, but it's nice to confirm
You can get the rings from renault for circa £30 a set each. Part #77 01 472 823.
I'd not be overly confident codging it together like that tbh but might be worth trying, you sure the block hasn't been damaged when the crank bent?
£30?!
i was told its massively more! - and my dialogys confirmed it - £120 isn't for 4, it's per cylinder
and i'm hoping the crankcase is ok!
if you could have a look for me :)
all the people i've contacted (motorfactors, engine builders, APD etc...) can't get hold of them
£30?!
Mine says £30 for a set £120 for 4x set. I'd ring your local stealers first before you write it off, my version of dialogys is from late 2007 so its much more up to date than the old 2003 version that gets sols on ebay. Hence the prices aren't very reliable from that.
http://www.gosnays.co.uk/
ring those fellas matt.
im sure they deliver but if not i live about 3 doors down so can collect and send them..
they sell so many parts for obscure engines i'd quite happily gaurentee you they can get them/have them in stock..
phoned renault, they said £36.01 inc the vat per piston, which bmh.01 said. they gave the same part number too
gosnays said they didnt have anything for the F4R
so looks like i might as well get them ordered from renault. about £144.
then i'll need to get my block honed and check the mains to make sure the old crank didnt fook them, but i suspect its ok!
how the hell haven't you lost motivation yet?
i've lost motivation because i went to check on the car last weekend after it rained ALOT! to find a 2 inch puddle behind each bucket seat, and the drivers seat to be soaked through with smelly rain water. serves me right for not sealing the sunroof panel, but i wasnt expecting so much rain! :(
i almost have mate :(
but it needs to be done, and im so close!
found a machine shop who can hone it for me. i'm going to get them to check the crank first though, to make sure its ok... as i really want to be sure
then hone it, new piston rings... and away i go!
the rest of the conversion is pretty much done anyway (it drove to FCS and did the track time)
Glad you're still moving forward with it fella! Will be such a weapon when it's making proper power!!
