Re: Valver Track Car Project Thread
Big progress today, very pleased. Thanks first of all to Daz and JB for the help, much appreciated Team!
I'll maybe type a few bits as we go, but ive got no end of pictures uploading so I'll try and let them explain.
THE whiteboard:
Troops arrived
Old (actually new) bushes out of the wishbones to make way for powerflex poly's
Tweaking subframe slightly
Degreased and cleaned up subframe
Took the already cut out n/s door off and set about removing the heavy impact bars. Cut it in the middle, drill out spot welds both ends, unstick sticky stuff, done. 6kg each, easy weight!
And back on
Exhaust off
-JB- removing rear seat brackets. Spot welds drilled out again
O/S door removed now and i set about stripping it down and cutting it out to match the other side i'd done previously. Me on the grinder again
Done
Rear seat brackets gone
Heater matrix out
Steering column re-welded. Not the best of jobs by whoever did it previously
Quickly growing rubbish pile
Opie oils goodies
Doorless O/S
Both door bars out now, 12kg between them!!
New rod ends on willy rack
Old cambelt off
Alternator belt tensioner made
New parts
Impact bar-less door
Mess
New belt on having checked and double checked timing
Bible
Possibly the most expensive tensioning stick ever!? Haynes quoted something like 22lb should see 3mm of movement in the belt, so we worked that out to be almost 10kg and made something up to suit. Improvisation at its finest. £14 litre of gearbox oil and £36 of engine oil mated to a door bar, mintage!
Rather pleased with the creation
Williams steering rack on
Powerflex poly bushes
Outer sleeves tacked onto the subframe to prevent them turning
Door back on
Low temp fan switch on
Grotty old thermostat out, need a new seal before the new low temp one goes in
Wishbones done
New rod end again
They fit
Powerlex inner ARB bushes put in with new clamps. What a ball ache they were! Hammerite kurust on the subframe too in preparation for some touchup paint
Loop pipe swapped over from the valver rack
And that was todays work
Chris
