MK1 2.0 16v Turbo
Looking good.
From experience you are going to have sooo many problems with the manifold. I garentee those welds will crack after time. Log type manifold is better but even these seem to warp and crack.
yeah im aware its going to crack :( one of the biggest pain jobs to do aswell, as im going to have to remove the head/engine to get the manifold off
If you can somehow re-enforce those welds, then try to. I replaced all my exhaust mounts and tried giving the system more support just to take abit of stress off the manifold. But its difficult to stop warping and expansion.
Some manifolds have a cut on the mating face of the manifold to allow for expansion.
I have had to remove and weld mine twice now!! lol
ah right, well i've got to fit all new rubber mounts on the system anyway. plus im looking into a mani/turbo brace to the block to take a bit of weight strain off of it
Exhaust is finally all put together and worked out after much hassle!! Found a nice section of flexi piping :)
Also put my battery box in
Tomorrow is D-Day (decision day) on rear brakes wether i mod them or keep standard as i'll be hearing from/visiting the machinist
Just read all 13 pages and it was well worth it!!!! Great project, like how you've just picked up bits off ebay and tried to make it all work! Amazingly impressed considering your not a mechanic! Good work! Can't wait til i have an income that means i can try things like this!
Looking good.
I concur with some of the above ...
I just saw this thread and read the first couple of pages (will finish the rest in a bit) and my immediate thought was the manifold and turbo - it is in clear need of a turbo stay IMHO to prevent cracking/failure of the manifold which I would say will occur otherwise. I have had a fair bit of experience with turbo installations on various cars and have had tubular manifolds made before and have experienced issues with no stays.
It shouldn't be too hard to make a stay up to support the turbo though if you haven't already.
I also hope all the welds have been cleaned up inside the exhaust manifold too but that should be a given and it looks like a comprehensive job ...
Looks a great project though and I love turbochargers :-)
Martin
this is cocking fantastic.
Think i saw the start of this on c16v then managed to forget about it.
Just read through the lot and i'm massively impressed with all the fabrication. I just wouldnt know where to start with everything!
Wrapped the downpipe today. Bought 100ft of exhaust wrap and still have miles left :lol: so going to wrap the decat aswell lol doesn't look to bad, sprayed it with some silicon stuff for heat wrap ?
I'd leave it. You've got the DV in there to protect the compressor from really high pressures, It's just stalling a bit when it builds real boost up. I'd leave it for the noises tbqfh!
I got the same problem with my R19 Turbo.
When you drive it, and go all the way... (change the gear at 6000 rpm) it won't stall anymore... :).
Lil update
FINALLY got my hubs back after sending them off again to be reduced further
Bolted them on
Fitted the studs
Slapped a disc on
then put the pad carrier on to see wahst what wehn it comes down to moving the calipers out for them
A little unsure as wether to drill and tap holes for a disc retaining screw at the moment...
Discs are 265mm
Put some rimtape on the wheels
This pic also shows what happens when you use r19 16v wishbones inplace of Williams, they induce too much castor
