Mine had the exact same type of split at the exact same place Chris, I put it down to heat from the exhaust manifold getting to hot and now have my new pipe re-routed around the left side of the engine bay away from the exhaust
Ok thanks,
I think it split after it was mapped.
Could it be down on power because of this hole in the pipe?
Where did you get the new pipe from as i also wanted to route the pipe to the left hand side of the engine.
Cheap and hard enough so that it won't deform under suction or anything
LMFAO... that made me chuckle like a little school girl![]()
This is when it all gets a bit nasty,doing all the little bits and bobs.
your mirror arrived then
Did Santa get you anything nice ;-)
Your list sounds pretty good.
You make it sound like you wire tucking the new loom?
