Clio 182 Trophy Spring Detail (first time rotary)
aucky
Car  N
Spring is here, time to get rid of the swirls from the harsh winter.
I’ve used a DAS-6 a few times and achieved reasonable results but now I’ve decided to upgrade to rotary in the form of a cheap and cheerful Silverline.
Due to time restrictions and it being my first time I’m only aiming for about 80% correction (I use it every day anyway).
Apologies for the amateur camera work. Its an ancient point and shoot which keeps flicking itself to video so I just take the shot whenever it decides to work!
A few before shots:
I found some AG wheel cleaner in the cupboard. Probably stronger than my usual bilberry solution..
Iron-X’d.. so THAT’S what that brown stain was!
Arches given a quick scrub
Wheels given a layer of Jetseal.
Car jet washed and foamed with PH neutral foam, shuts, trim and details agitated with a soft brush
Dodo SN still holding up after winter
Washed using TBM (grit guard in the rinse bucket), with Dodo BTBM and a sheepskin mitt.
Tar removed and Iron-x’d
Time for clay (and a beer)
Sonus green clay, Dodo born slippy lube and a mug of hot water
Pretty clean..
found some!
Ooops! In the bin it went
Washed again with BTBM and sheeted off with an open hose.
Clean. That'll do for today!
Day 2
I was of course greeted with this..
Various before/after shots
Menzerna [FONT=&quot]PO 85 RE 5 on an orange polishing pad, followed by ( I can’t remember the name, menzerna something) on a finishing pad. [/FONT]
I knew I wasn’t going to get the whole car polished in a day, so I decided to lay down some protection as I finished each area.
Following polish each panel was wiped down with IPA/distilled water 50:50 solution and treated with Werkstat Prime Strong by DA on a soft pad.
Jetseal 109
Day 3:
The car was soaking from the misty weather. Doused with water and dried off.
The first coat of Jetseal from yesterday is doing the trick:
I then realised the zip on my trackies had been rubbing on the door. Back to square one! :mad:
After 2-3 coats of Jetseal I applied 2x Coats of Dodo Supernatural (an hour or so apart)
I had hoped to get some arty shots but the location I was going to use has since been gated off. So out of ideas and out of light I headed home.
Very happy with the results.
Thanks for reading, comment welcome :)
Loving the end sticker! Except not many people will understand it!
re dropping the clay, here's a quick tip; put old but clean towels down under where you are claying. That way, if you drop the clay, you can carry on :)
Other than that, great results!
Great results mate, such a great colour when properly cleaned.
I really want/need mine to be PC'd!
Thanks.
Good thinking batman
Nice detail there mate, as said its a fantastic colour once machine polished/brought up to a high standard...still one of the best cars i have detailed.
That is stunning! I have decided, I'm getting a Trophy next.
Can you come and do mine, it needs a machine polish desperately!
I'd say correction comes easier with the rotary so in that sense, yes.
However compared to DA the rotary tends to go where the hell it wants sometimes and you just have to go with it... so less controlled than the DA. Thats why I used the DA to apply some of the products.
It's looking good mate, red cars are awesome! Trophy's are very awesome.
I find with my car and Red's that they aren't the most reflective colours.
I thought my blue would have been good but they aren't great, needs to be a darker blue for reflections to work I think.
One of mine...
Maybe it was my crap camera making them a little hazy. I'll try again with the new one.
Wow stunning... I love my detailing and I'm swapping the das 6 for a rotary as I keep getting asked to do modern stuff after people have seen my beetle and I just dont think it's up to some of the hard modern finishes. Top work red always looks stunning but that is exceptional! just what a trophy deserves
I've seen a lit more hard than soft. Clios were 95% hard imo.
looks brilliant you've done a great job. Reading this made me feel so guilty about the lack of polish mine sees.
Cheers guys.
I'm in the process of buying a house with an oversize garage, so I'm predicting the winter protection detail to reach new heights of OCD and back pain.
....and I can't wait.
