Cheers Andy will have to come out in yours when i next see you at a trackday
Few bits to sort over the next couple of weeks, i have to miss the trackday at cadwell due to work commitmets :dapprove:, but Donnington is at the end of july so ive got a few bits and bobs to keep me going until then.
1. Sort the wishbone out - Rang powerflex and they are sending me out a new set of wishbone sleeves. Going to get those tack welded in as i did before, replace the wishbone bolt as that is slightly bent. Then im just going to run it at donnington and see what happens before i go changing the subframe.
2. Ordered a new V6 air box from Tom @ wests renault, so going to get that on.
3. Sort the driveshaft out as it has leaked abit of cv grease, need a smalle hose clip really. Cv grease on the way.
4. Sort out the leaking sump gasket, its not leaking alot but id rather sort it than leave it.
5. Fit a bias valve, as the rear of the car was abit livley at mallory park.
6. Fit my AST solid Topmounts, sort the tracking and camber and get two new front tyres fitted before Donnington.
