Technical Data sheet says 30'oF-200'oF christ knows what that is in Celcius.
Ok strange question, If i spray an alloy in red then mask off to do another part black, will the mask fetch off the previous colour of red?
im waiting for it to arrive, i will post more when the time comes.Anyone tried this on the black trim yet?
Hi mates!!
how many bottles do you use for paint a single wheel?
If you read though the thread I'm pretty sure this has been covered already but I used 3-and-a-bit cans for a set of 4 wheels so less than 1 can per wheel
sorry nick you have reason! i'm italian and isn't easy read 10pages..
thanks a lot!
Anyone used the blue? Curious to see what shade it is
I used the blue this weekend. I can stick up some pictures if it helps?
Its quite a light blue. Not as dark as they say. My car is albi blue and I'd say the blue is closer to the racing blue.
Got to say I've used this stuff on my wheels/badges and interior pieces. It's really good stuff![]()
Is this plastidip stuff easy to use? I.e. I'm pretty crap at spray painting - it usually ends up orange peely!
Does this always give a good finish, even with the glossy layer on top?
No problem, here you go.
It comes off very easily if you don't like part of it or make a mistake.
Forgive the general mess of the car. Sadly having been in and out of hospital, then on holiday and working shifts has meant it hasn't had a proper clean in 3 months![]()
Has anyone sprayed the insides of their wheels? How does it react to hot brake dust particals landing on it?
Also, Does anyone think Damper temps are likely to exceed 93degC (extra heat cunducted from the brakes). I havent got a IFR temp gun :/
I'll be doing the insides when I spray mine
