100% complete 172RWD! - updated
New bits ordered.
Fuse/relay plastics for front
Strut braces omp
Solid top mounts
New coolant pipes for turbo ;-)
Turbo oil pipes
Oil cooler kit
Cars going back to k-tecracing
End of the month so updates soon.
Still could be looking for a v6 pedalbox and all parts
For the clutch.
Steve fitting a Manual Rack is awful!!! more the ock to lock is massive comapired to a sport rack!!! ended up bidding outs on the mk!! and fitted rack with greased and blanking it all off ( a little pikey tho)
Iv noticed the tracks about 40mm shorter lol
I now have massive toe out lol.
Need to swap over bits from old rack.
It only mounts on 2bolts too!!!?
Is that because the power rack has more power to shear bolts?
More new parts on way thanks to
Cliospares thanks Josh.
Oe fuse relay box
Front seat belts
Dash parts
Looms bits and bobs.
Pipes
Dash clock
Boot stutsx2
Rear plate lamp
Plus many other parts.
As soon as iv done all the easy bits.
It's going back for wiring and fuel line plumbing.
Then hopefully then some mapping .
good project mate, refferance the rack. Why dont you just run the std 172power racl and use an electric pas pump of another car... like an astra... not like your short on room in the front lol
Already changed it over now so it's staying.
Don't need pas anyway it's very light.
wow iv just sat aread this whole thread my eyes are now killing me!:dead: This is a hell of a motor and im one jelous mo fo! is there any vids of it in action yet? cheers spoony
just new chargecooler pump.
and some 76mm ducting hose for the rear windows scoops.
next up is plugging in
alot of wiring dash/ecu
finish off exhaust
new boost hoses/pipes
fuel pipe/pump.
gear linkage tweak.
clutch cable poss change to hydr clutch from v6.
i hope its not too long now
Steve, if your struggling to get a v6 pedal box, I'm fabricating an alternative for my project, let me know if your interested and ill keep posted :D
good to see this is still going mate. Lack of power steering might not be so bad with the lump relocated. In FWD mode it's horrendous with no power steering.
No not giving up far from it,been very busy with it last couple months.
I don't want to make any mad claims but I hope to have it running properly by Christmas .
Left to do
Wiring engine ecu up to dash 2
Finish water pipes front rad to rear.
Hydr clutch and pedalbox from v6 fitted.
And some other bits and bobs fuel pump,switches,chargecooler pipes pump etc.
Rear cover(v6)naca window ducting to rear cover,etc
