Renault Clio 1.6 16v K4M Turbo
some photos of the new kit
Could you PM Me the price too please as my mate has this engine. Cheers
Out of curiosity what power are you getting from a standard 1.4 and 1.6 with just the bolt on kit?
already sayed, in the 1.6, just with 0.5bars of pressure 172hp, without ecu mapping
in the 1.4 never took to the dyno
How will this work without ecu mapping as the highest break point of the manifold air pressure in the ecu is 1048mbar?!? Do you use another map sensor and modify the fuel pressure??
stock manifold, stock map sensor, if you use the stock injectors u need more fuel pressure, if u use bigger injectors, stock pressure
But how do you explain to the ECU that it is operating at a MAP over 1048mbar and has to increase injection time further if you didn´t remap?? Does your Clio have a returnless fuel system (pressure regulator in the fuel tank an 3.5bar constant against ambient pressure), or do you have the old system with pressure regulator at the fuel rail and 3.0bar constant against MAP?
stock 3bar fuel regulator with stock fuel return to the deposit
air/fuel readings 13, 14 mixture
the second turbo kit, its much more expensive, it have a intake manifold, no a/c, electric direction and more
Can i have pricing details for this please, and can this only be fitted in portugal or is it a fairly straight forward procedure, Thanks
Andrew
Definately interested in these. How much we looking for the kit. Website does not list everything does it?
How difficult are these to fit?
lots of injectors on the market for this car
this kit was fab to be plug and play with no cutting involve
